Old 01-03-2010, 11:41 PM   #1
66scottey
Question best way to go 4x4
i own a 1965 c 10 and wont to make it a 4x4 on a low budget thinking about a 4 or 6 in lift idk what frame to look into buying or 1/2 ton or 3/4 ton frame?
66scottey is offline   Reply With Quote
Old 01-04-2010, 03:17 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: best way to go 4x4
Frame is basically the same for 1/2's and 3/4's. If you can't find a frame of your vintage, I would try looking at the 73-87 frame. 35"s are fine with 1/2 ton, but 3/4"s would be better if you should ever get the need to go bigger. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-04-2010, 03:43 AM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea x2. Way easier to go with 3/4 ton the first time around if you think your gonna want it later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-04-2010, 03:47 AM   #4
woodwright
Enjoying left field
woodwright's Avatar
Is there much of a weight difference between 1/2T and 3/4T?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 01-04-2010, 08:09 AM   #5
Nothing significant.Less than a passenger.The`73-ups are very plentiful.Measure your wheel base and go from there.Is yours long or short?If short and the later are too long,stretching a K/5 frame is another option.
Old 01-04-2010, 11:51 AM   #6
66scottey
ok thank you im going to look into a 3/4 ton frame mine is lwb but wont to make it swb
