Old 01-25-2003, 11:44 PM   #1
casey
casey's Avatar
Best solution for sticky lifter
I got one sticky lifter that keeps acting up, any good solutions, it's ticking me off
casey is offline   Reply With Quote
Old 01-26-2003, 12:04 AM   #2
meathead95
computer illiterate
meathead95's Avatar
I have a buddy that put a quart of marvel mistery oil in when he changed his oil in his daily driver and hasnt had a problem since and its been a couple of years now
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 01-26-2003, 12:04 AM   #3
Stroker
Can you give us a little more information? By acting up do you mean you have a ticking sound, or are you having to adjust the lash over and over? Is this a new engine or an engine with a lot of miles on it.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 01-26-2003, 12:46 AM   #4
crazy4chevs
crazy4chevs's Avatar
Its possible that your adjusting nut is bad. Somtimes they back off try replacing it and see if that helps.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 01-26-2003, 12:57 AM   #5
bigjimzlll
bigjimzlll's Avatar
do a little research...check the rocker arms,pushrods and adj. nuts..It may just be a stuck lifter, but if a pushrods gone south, its best to find it quickly
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-26-2003, 01:04 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I've had good luck with some automatic transmission fluid, just dump a quart in next time you need to add oil, run it about 100 miles and change oil......it knocks all the sludge and crap off the inside of the engine and can get rid of the varnish that causes lifters to stick.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 01-26-2003, 01:09 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've done the dextron thing too...works great.
Old 01-26-2003, 01:23 AM   #8
crazy longhorn
Fabricate till you "puke"
I have also used ATF or marvel mystery oil ......they both work . crazy L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-26-2003, 01:31 AM   #9
casey
casey's Avatar
Stroker The motors about two years old, the lifter starts ticking for a while then stops or if I shut it off for a while then restart its gone. Whats marvel mystery oil and where do you get it?
Old 01-26-2003, 01:39 AM   #10
crazy longhorn
Marvel is a top oil addative that cleans varnish. you shold be able to find it at an auto parts store,or farm supply store. It is usaully in a red colored tin can, with a screw off cap. If you cant find it , the ATF trick should work as well........crazyL
Old 01-26-2003, 01:54 AM   #11
eraser87
Truck Fanatic
try a can of prolong engine treatment
eraser87 is offline   Reply With Quote
Old 01-26-2003, 04:48 AM   #12
68 Suburban
68 Suburban's Avatar
I would read this before I forked out the $$$ for the Prolong Engine Treatment.
http://www.ftc.gov/opa/1999/9909/prolong.htm
68 Suburban is offline   Reply With Quote
Old 01-26-2003, 07:50 AM   #13
nevada70chev
same problem....
i got a target master 350, don't know the exact miles but have a definite tick, adding the ATF works to loosen the lifter? how exactly? the engine doesn't burn or use oil so i want to just get the most miles out of it, thanks
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 01-26-2003, 09:57 AM   #14
Blazer1970
Blazer1970's Avatar
If you really want to fix it right, pull the intake and pull all of the lifters (keep them in order, they have to go back in the same holes), and take them all apart and clean them in solvent. This is what the old factory service manuals recommended. There is most likely a piece of crap floating around inside one of the lifters that is sometimes blocking the check ball from sealing.
Blazer1970 is offline   Reply With Quote
Old 01-26-2003, 10:37 AM   #15
71k5
I like the marvel mystery oil, too. Use it for a couple of oil changes, and by the way, it works great as an air too lubricant. Just squirt a bit in the tool air inlet every now and then...
71k5 is offline   Reply With Quote
Old 01-26-2003, 11:20 AM   #16
Pont
I need another Barley Pop
Pont's Avatar
I've also had good luck with a product called "Rislone" on past lifter issues. It's in a yellow can with red lettering.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-26-2003, 11:21 AM   #17
71k5
that's air tool, ha ha!
Old 01-26-2003, 11:33 AM   #18
casey
casey's Avatar
Can you run these products or a little tranny fluid in your oil all the time, or would it thin the oil to much, I keep thinking I heard that some guys would run a 1/2 a litre in your oil all the time, never tried it though.I put about a 1/2 litre in last night and the little ticker seem to stop, but only time will tell, I guess if it persists I'll have to do what Blazer1970 said.
Old 01-26-2003, 02:00 PM   #19
crazy longhorn
Casey, the Marvel or the ATF I usually ran 100-200 mi, then changed the oil. Rislone is an addative that you can run to replace 1 quart of oil with every change......I have also used it, & not seen a bit of trouble....crazyL
Old 01-28-2003, 03:44 AM   #20
nevada70chev
ok...i'm going to try the atf remedy
i figure the old truck is about due for an oil change, so i added a quart of atf. i'll let you know my results, thanks for the info.
Old 01-28-2003, 04:03 AM   #21
casey
casey's Avatar
I tried the tranny oil for a couple of days now, no ticking, I'll change the oil soon, keeping my fingers crossed
