01-04-2010, 12:24 AM | #1 |
What are you with 6 cyl using for muffler/exhaust?
I have a 292 with no muffler and pipe is cut under seat
I was just wondering what others are running for muffler so that I can get some Idea on what is out there. Thanks |
01-04-2010, 12:33 AM | #2 |
Re: What are you with 6 cyl using for muffler/exhaust?
I used the top rail of a chain lenght fence on my 250 it made a nice little pee shooter sounded good. no muffler
i put a 350 in it now so no more fence railing |
01-04-2010, 01:06 AM | #3 |
I have a 230 in my 64, and just bought a set of headers and cherry bombs for it. You have about as good of a sound as you can get out of that stock manifold, go for headers if you want it to sounds better. Either Summit or Jegs sells a pair for $130.
1982 K10 SWB 1987 V20 - Sold - Doh! |
01-04-2010, 09:57 AM | #4 |
Duals with glass packs.
Back in high school (late 70's)..... I ran a 230 I6 in my first car, a '70 Nova. I had very little money and the guy that ran our shop class was an old motor head that just loved the old stovebolt motors. He helped me make a split exhaust manifold. I then used Thrush glass packs. Sounded sweet and had a unique sound. Last edited by lakeroadster; 01-04-2010 at 09:57 AM. |
01-04-2010, 10:34 AM | #5 |
Hollister, CA.
My came with a fairly new Flowmaster exhaust system....one into two, then split in front of the rear wheels.
It sounded good, but I'm replacing that for duals with glasspacks. I can cut it up and ship it to you if you'd like ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
01-04-2010, 12:51 PM | #6 |
Farmtruck desciple
That's a single exhaust, so you will need:
http://kalecoauto.com/index.php?main...&products_id=3 If it were a V8, you would need the one for dual exhaust: http://kalecoauto.com/index.php?main...&products_id=2 |
01-04-2010, 01:54 PM | #7 |
Hey Y'all!!
On my 65 longbed, the previous motor was a 350 with dual exhaust and turbo mufflers with the pipes exiting under the rear bumper. I installed a 250 and just tied into one side of the exhaust and left the other side hanging for the time being. Oh, and it's 2 1/2" piping too!
My ultimate plan is to install an original Sprint6 (late 60's Pontiac) intake/manifold combo so it will have a 4 barrel and true dual exhaust...one day...
Just hopin' I live long enough to finish something!!! |
01-04-2010, 07:41 PM | #8 | |
HOW long until spring??
I have a stock exhaust manifold now but I talked to a local rod shop who will split the the manifold for $125.The plans include new tailpipe and a smithys or cherry bomb out the back
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 01-04-2010 at 07:42 PM. |
01-04-2010, 08:04 PM | #9 |
Junior Member
I had Smithys behind this motor and it sounded ok. It just depends on what sound you are looking for. If you want that old time rap-rap sound you might want to consider these. I used them and they were mellow till I got on it and then it was quite raspy!
You would find these in a corvette parts magazine. They used them in some Vettes.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 01-04-2010 at 08:04 PM. |
01-04-2010, 08:52 PM | #10 |
nice info, I was thinking about cherry bombs myself. I have also found headers on ebay.
01-04-2010, 10:31 PM | #11 |
Junior Member
I ran the long tube headers but the shorties look better on these motors.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
01-04-2010, 10:51 PM | #12 | |
I have a 250 with clifford intake and a 390 holley but still sitting with the stock exhaust manifold and simple muffler and want to make it sound better but not that raspy sound.
Tommy~ The difference between genius and stupidity is that genius has its limits -- Albert Einstein 63 build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=317341 |
01-05-2010, 04:29 AM | #13 |
I put the long tube headers on my 230, now I wish I had used the cast iron headers from Stovebolt. I had trouble getting them to quit leaking, I got the headers from Summit latter found the cure from Stovebolt witch is a thicker exhaust gasket with studs instead of the stock bolts. The studs are coarse thread to the block and a fine thread nut to pull it down good. I have the Purple Hornies with the 3 bolt header flange. Anyway they are loud but sound good I don't have tail pipes on it yet so I think that will quiet them down a little. My neighbor came over and said what kind of motor did you put in that ole truck. I told him the one that came with it. Here's a couple of motor pic's
---Vernski[ BTW I had to move a bunch of things around to make em fit] |
01-05-2010, 08:32 AM | #14 |
Junior Member
I had a couple of spots on the long tube headers that were 'adjusted' by their previous owner to fit. I believe the shorth headers are better.
As far as sealing, they are a pain to get the exhaust to seal no matter whether it is stock or headers. It takes a steady mind, patience and or a second person. The copper sealant works best. There are some articles on getting the exhaust/intake bolted up correctly.
01-05-2010, 04:02 PM | #15 | |
01-05-2010, 11:06 PM | #16 | |
01-05-2010, 11:40 PM | #17 |
01-06-2010, 12:03 AM | #18 |
Junior Member
I think it is his idea of a joke fellas
01-06-2010, 12:38 AM | #19 |
Cross drilled brake lines!
01-06-2010, 12:44 AM | #20 |
Well I'll be horn swagled he got me good, I didn't think anything was fishy until I looked at the site the second time and seen this add for a muffler bearing. Ha- Ha jolly joker some people have to much time on there hands. Must be the cold weather keeps em at the pc to much.---Vernski
01-06-2010, 01:57 AM | #21 |
O pipe. Funny stuff. Same place you get the rotary girder, right?
I'm still assembling, but I have Langdons cast iron shorties for my 292 and plan to run through Cherry Bombs. Yes, I'm re-living high school '75 and boy is it going to be fun!
292 + TKO500 |
01-06-2010, 01:13 PM | #22 | |
I always wondered where you bought blinker fluid, and seasonal tire air...........And the wiper sharpener...elbow grease.. Too funny!!
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
01-07-2010, 01:09 AM | #23 |
my long bed has a 250 with clifford intake and long tube headers dual 15'' glass pacs spitting out of bellflower tips sounds sweet!!! Hey Chief still got that offy if your still interested also got some used bias wide whites
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-07-2010, 01:55 AM | #24 | |
01-07-2010, 10:58 PM | #25 |
It works great. The holley is acctuly a 2bbl 350cfm
