My Zed and bagged 71 gmc
I picked this truck up a little more than a month ago,it was stock height and was a nasty blue color.So far i have Zed the front 3'',lowered the cab mounts 1'' and Zed the rear 5'' with a small c notch also.Bagged with stock trailing arms and waiting for my spindles.Will post pics as i go.
![]() Join Date: Nov 2008
Re: My Zed and bagged 71 gmc
Great job!...That lowering procedure seems pretty familiar..
Thanks Puropedo,i have read your thread more than once and learned alot of tricks.
Is your truck a long bed? Do you have any more pics?
Ya,it's a long bed.I should have the bed back on this weekend after i finish reinforcing my notch,then i'll take more pics.I still have some wiring left to do and need to raise the bedfloor but it's starting to take shape.
I see you got the drivetrain in there, did you have to cut the tranny tunel? What kinda airbags are you using for the rear?
the tires are 255-35-20
Like the stance of your truck alot man! and those gmc fronts are a refreshing change of pace
Thanks speedracer,i don't see many GMC's around,so when i found this one i knew i had to pick it up(especially since i bought it for $800 bucks!)I will hopefully have it rolling this weekend,just have to bolt the front clip on and raise the bed floor then take it for it's first ride on air.
Haha I really would like to switch off a chevy front end for a gmc front end just to have something different
It seems like the gmc's are getting pretty hard to find,atleast around here.I have always thought they looked good,but alot of people prefer the chevy's.Either way,the 67-72 has always been my favorite.
#13 |
it looks great lowered or I should say slammed!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#14 |
Project collector
This looks sweet. I have a 71 GMC longbed I am planning to do along these lines. Have to finish my current project first though. Keep up the good work, I will be watching to see how she turns out.
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
#15 |
Thanks for the complements guys,i will hopefully have some new pics soon
#16 |
low n' slo
![]() Join Date: Mar 2009
that looks good man, did you z it with the motor and trans in?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#17 |
Ya,i just pulled the front sheetmetal off and there was enough room to Z it.
#18 |
New pics
#19 |
low n' slo
nice...you got any close ups of the front z?
#20 |
I will take some more pics soon.I still have a few things to finish up,then i should be driving it soon.Still trying to figure out what i'm going to do with my exhaust...anybody have some suggestions on what kind of headers i should run?Its a 350 and there isn't alot of room under the truck.
#21 |
Found another pic
#22 |
Did you angle your Z?Your front wheels look rather centered in the pic
#23 |
New pic...still need to replace the rockers and do a lot of bodywork,but got sick of it being black so i sprayed it with a semi gloss yellow.What do you guys think?
#24 |
what did u do to your front suspension like what crossmember and your spindles did u use stock or drop spindles did u go belt driven or compressors thanks for the info
#25 |
Grandpa in the rustmobile...
yellow looks awesome!
I gotta ? nottrying to be a smart .... but why paint your truck if its going to ride that low and take off all the nice paint? Or does it go up enough not to scrape over bumps? Looks sweet slamed but how do you take care of the prettty paint?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
