Old 01-04-2010, 02:09 AM   #1
dmartin1
dmartin1's Avatar
3/4 4x4 question
does anyone know what the front and rear axel on a 1979 3/4 chevy 4x4 camper special are?
or do you need some pics?
i know the rear is some 14 bolt
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 01-04-2010, 02:49 AM   #2
wildwilly4x4
Re: 3/4 4x4 question
Probably a 14 full float rear and 10 bolt front. I have heard of some 3/4 having a 44 in front, but my experience has been that most after '78 were 10 bolts. Doesnt matter much though, they are pretty equal in strength.
wildwilly4x4 is offline   Reply With Quote
Old 01-04-2010, 08:13 AM   #3
Got a picture of your front axle?No doubt about the rear.
Old 01-10-2010, 10:20 PM   #4
dmartin1
dmartin1's Avatar
is the 14 bolt rearend posi?
sorry,im not very good at axel stuff.haha
65 nova
And more
Old 01-10-2010, 11:24 PM   #5
b454rat
Look in the glovebox or under the hood for the RPO codes. Look for G80, that will be a Govlok. If that ain't there, pop the cover and take a look. If you see spider gears, it's open, and if you can't really see inside, then it's a Govlok.
As already stated, could be a Dana 44 or a Corp. 10 bolt. Same strength either way. Dana will have a stop sign sorta shape to it, 10 bolt will have almost a round cover. Also 10 bolt will have 2 tabs at 5 and 7 o'clock positions.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-10-2010, 11:30 PM   #6
geremy
does your reand have four bolt holding the front pinion bearing in now your front end is cover smoothe or does it have ahump in it
geremy is offline   Reply With Quote
Old 01-11-2010, 02:17 AM   #7
dmartin1
dmartin1's Avatar
the front has a hump in it...on one side it has the big lump in the case.
ill check about that rearend tomorrow.
thanks for all the info!
so if it says gp80 or whatever its posi?
65 nova
And more
Old 01-11-2010, 07:02 AM   #8
Yes,posi.I`m willing to bet it`s a Dana44 in a heavied up pre-80 K/20.To avoid confusion I call the rear a rear,same as a 2wd.I call the front axle...what I just said.The full name is front drive axle,but we can assume it`s a drive axle when we`re talking 4wd.I might say front end also.We use "rear" in place of differential.That works on 2wd w/1 drive axle/differential (in the rear).Front differential works well for referring to the front end.
Old 01-13-2010, 09:24 PM   #9
hatzie
Moderator
hatzie's Avatar
Originally Posted by dmartin1 View Post
does anyone know what the front and rear axle on a 1979 3/4 Chevy 4x4 camper special are?
I have a 76 K20 Camper Special with Dana 44 in front and 14bolt FF rear.
Google "Axle ID". The first two pages in the list will tell you what you have.
Old 01-15-2010, 12:11 AM   #10
cobinder
Everything is work in progress
cobinder's Avatar
my 80 K20 has a 44 and a 14 bolt
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-15-2010, 02:54 AM   #11
Sub-versive
Boss Hogg
Sub-versive's Avatar
x2
Sub-versive is offline   Reply With Quote
