![]() Join Date: Jun 2002
disc brake swap question?
I have installed the ECE front disc kit on my 68, and bought new master cylinder/booster for a 72. My questions (2) are
1. Can I use the factory front brake lines with the discs? 2. If I opt to use a aftermarket adjustible proportioning valve (Willwood), do I need to use any type of check valves or residual valves also? Or should I just buy factory prop. valve/ bracket assy. Thanks in advance.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
I have the same kit on my 68 you will need to get new lines from a 71-72 with the lines that go in front of the a-arms 68 had the lines behind the a-arms
I would also buy a factory style prop valve for a 71-72 this way you dont have to worry about adjustments and compatibality problems The best way would be the get the prop valve and lines of a 71-72 from the mastercylinder to both front wheels. Also the one that connects to the rear wheels
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
![]() Join Date: Jul 2000
I used the 68 type lines coming off back of a-arm on my disc brake mod. I welded the brackets you get in the kit from ECE to back of the a-arms after cutting off the old brackets. Works great.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
