01-04-2010, 12:50 PM | #1 |
yes another torsion bar/air bag question
ok i'm having a bit of a problem/dilema with my 60 gmc.....i think this truck has been lowered before(rear frame was been clearanced for the frame to drop with air bags)now for the front,i'm curious if i can just remove the upper and lower A arms and replace with ones from a 82 chev pu.....the current cross member that is in there now has a plate across where a coil spring would go up into the cross member(on the upper part)and my buddy built a plate on his front cross member just like what i currently have and installed airbags with drop spindles.i'm thinking i might have a newer cross member in there,so maybe if both upper and lower A arms bolt up i'll be ok?
hope i didn't make that to confusingi can try to get a pic if it'll help at all |
01-05-2010, 01:36 AM | #2 |
60-66 Nut
Re: yes another torsion bar/air bag question
If you still have the torsion bars then you'll need to swap the whole front suspension crossmember and all. If you don't have the torsion bars then you may be able to just swap control arms.....pics may help ID what you have.
01-05-2010, 11:08 AM | #3 |
The lower A arm on torsion bar suspension is held on with 4 1/2 bolts thru a forging ,and the A arm is made of 2 deep c channels with a bolt on lower ball joint. Spring lower A arms are held on by 2 U bolts and the lower arm is stamped steel and very similar to the 70s and 80 s arms except for the pivot points these have a pressed in ball joint.
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
