Old 01-04-2010, 02:34 PM   #1
MrBlue
MrBlue's Avatar
T-5 Users, Shifter Help
Greetings,
We have purchased a T-5 for our 72'. So we could use some help in the shifter department. Knowing that the shifter will need to be longer that the S-10 style. What shifter works the best?
Thanks,
MrBlue
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 01-04-2010, 03:04 PM   #2
john
member #16
john's Avatar
Re: T-5 Users, Shifter Help
Heres a pretty good write up by brad on t-5's.
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
john is offline   Reply With Quote
Old 01-05-2010, 10:09 AM   #3
68_chop_top
68_chop_top's Avatar
Use the S-10 tail shaft and top shifter plate. Then any Hurst shifter will be able to bolt to the shifter stub 2 hole.
Be very careful with the T-5. They are only rated 295 ftlb of torque and they are not kidding. I have torn up 3 T-5 with my 327 in a 68.
If I had to do it over, I would save my money an buy the Tremec TKO 600
my 2 cents.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 01-05-2010, 10:15 AM   #4
cdowns
cdowns's Avatar
you can build whatever type of hanhle you wish and just bolt it up to the tab
