01-04-2010, 05:17 PM | #1 |
Electrical weirdness
I replaced my turn signal switch, floor dimmer switch, and the brake light switch. Everything works great but when I turn on my headlights, the right turn indicator in the cab comes on and stays on and the right turn signal doesn't flash outside the truck in front of back, and the rear tail light goes dark except for the side marker light. This is on the 1974 4x2 btw....any ideas?
01-04-2010, 05:21 PM | #2 |
Re: Electrical weirdness
Check all grounds. the headlight grounds are on the core support.
01-04-2010, 05:23 PM | #3 |
Robert Olson Transport
check the turn signal wiring harness make sure its in right and also make sure nothing could be arcing
01-04-2010, 05:35 PM | #4 |
Already did that, and it is all plugged in right at the connector. I tend to think it may be a ground deal at the headlights so I will check that tonight...any other ideas while I am online?
01-04-2010, 06:28 PM | #5 |
only other thing that comes to mind are you sure you have the right bulbs in the sockets? i had a problem when i had an 1156 in an 1157 socket
01-04-2010, 06:34 PM | #6 | |
thanks for the reminder! Kevin |
01-04-2010, 06:45 PM | #7 | |
The One And Only !!!
What's this !!! We have a psychic on the board ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-04-2010, 07:46 PM | #8 |
Addicted to Rust
No just the voice of painful experience.
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
01-04-2010, 09:06 PM | #9 |
i actually had pretty much the same problem execpt both my indicaters lit up. and also my gas gauge would drop wayyyyyy below E when ever i would turn my lights on. i had a spare cluster layin around swapped it in. problem solved.
