Old 01-05-2010, 01:35 AM   #1
Baged72
Baged72's Avatar
Truck wont run in 3rd gear??
Finally got my truck going so its drivable and it will lite up the tires 1st through 2nd and as soon as the truck hits 3rd gear it bogs down and will even shut off if I reach higher mph, any ideas???
400 smallblock
TH 350
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 01-05-2010, 08:23 AM   #2
sean1969c10
sean1969c10's Avatar
Re: Truck wont run in 3rd gear??
Could be running out of fuel, 1st thru 2nd running on what is in the float bowl and what the fuel pump can add but the pump ends up running behind and by the time you hit 3rd gear you don't have enough fuel in the bowl. Just my 2c worth
Sean
sean1969c10 is offline   Reply With Quote
Old 01-05-2010, 08:48 AM   #3
crushermechanic
crushermechanic's Avatar
x2 sounds like maybe the float level is to low. it could also be the pump is weak.
crushermechanic is offline   Reply With Quote
Old 01-05-2010, 12:00 PM   #4
longhorn396
S.D.M.F.
longhorn396's Avatar
my trans pump just went out of mine and it was doin close to the same thing. so it might be the pump
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 01-05-2010, 08:58 PM   #5
Baged72
Baged72's Avatar
I can drive my truck all day long in 1st and 2nd gear but once i hit 3rd it happens......
I have a brand new holley 600 carb and a new electric fuel pump, what is a transmission pump??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 01-06-2010, 12:02 PM   #6
longhorn396
S.D.M.F.
well the guy working on mine said that there is a pump right behind the first panel behind the bell housing on the inside. idk i have never worked on a trans but just my 2cents. idk
Old 01-06-2010, 12:13 PM   #7
69GMCLonghorn
69GMCLonghorn's Avatar
I don't think this is trans related at all... This sounds like a classic case of fuel loss, as prev stated. Even a new carb can either have a problem, or just can't keep up if your foot is in the secondaries... I've had this happen on a Chevelle that I had. It would bog down if I had the secondaries open for more than a few seconds. I'd take my foot out of it and it would recover, then I could nail it again... No wonder I wore that engine out!! I think the secondaries were open more than they were closed!
69GMCLonghorn is offline   Reply With Quote
Old 01-06-2010, 12:50 PM   #8
longhorn396
S.D.M.F.
i thought u meant it was slipping. my bad man. sorry bout the wrong info
Old 01-06-2010, 03:17 PM   #9
Baged72
Baged72's Avatar
It feels like its running out of fuel but... in 1st and 2nd dont the secondaries open up also? I have it to the floor throughout 1st gear and also 2nd, doesn't the carburetor act the same as it would in 3rd? Do i need a regulator that produces more psi? I have a basic 1 to 6 psi regulator and its on 5psi now.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 01-06-2010, 03:26 PM   #10
longhorn396
S.D.M.F.
Its probably like everyone else is sayin. it probably just sucking all the gas and not getting enough to get it back in time. and yes they do open also. Not sure bout the regulator psi. Do someresearch and u might be able to find it.
