Old 01-05-2010, 01:44 AM   #1
rex01atv
How to adjust rear adjustable Track bar???
What is the simple way of adjusting this bar for centering the axel from side to side??? Any advise helps! I'm using early classic adjustable on air ride suspension with trailing arms??
rex01atv is offline   Reply With Quote
Old 01-05-2010, 07:52 AM   #2
dznucks
dznucks's Avatar
Re: How to adjust rear adjustable Track bar???
When I replaced my rear suspension I adjusted mine by measuring the distance from the rear inner wheel well to the outer edge of the tire. This was just to get it close enough to drive it too the alignment shop.
dznucks is offline   Reply With Quote
Old 01-05-2010, 08:05 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
pretty simple..
set your truck to ride height
measure from you rim to inner wheel well
adjust accordingly
I recomend send you truck off to an alignment shop just be sure they DON"T ADJUST YOU AIR...also guages and a sharpy work well....I marked the face (glass) with a red sharpy so you can hit your ride height at a quick glance
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-05-2010, 10:16 AM   #4
Shane
Shane's Avatar
don't measure to inner wheel well, as sheetmetal can be "tweaked" and is not a fixed point on the frame rails ... measure from wheel to frame rail
Shane is offline   Reply With Quote
Old 01-05-2010, 10:37 AM   #5
rex01atv
Okay, so dont take tires and wheels off, and set back of truck to ride height???
Old 01-05-2010, 11:58 AM   #6
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I would say, if you need to (or just want to) take the wheels off for better access to the parts, go for it. Just use a straight edge on the flat surface of the drums (or disk, depending on your application) and measure from there. But as far as ride height, I would say yes set it at ride height so you know everything is where it will be while driving. That way it'll be the closest to your desired measurements. I don't have bags, nor do I fore see getting them in the future, No money for me. But, that is what I would do if I did have them. I hope this helps you out a little.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 01-06-2010, 12:31 AM   #7
rex01atv
thanks!
