>130dB Moderator
BBC Rad. Straight swap?
I'm looking at upgrading my radiator in the near future and was looking at LMC's measurements and it seems that a rad for a 454 BBC would fit, it's just thicker. Anyone know if this is a pretty straight forward swap? Can I just swap radiators and the top "cover" and fan shroud and be ok?
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Re: BBC Rad. Straight swap?
The bbc one should bolt in but most big block guys run the diesel radiator its the biggest.
Gettin It One Pice At A Time
I would think so. Bbc did come on these trucks, and as far as I know the core support is the same regardless of motor. I think that there might be a different mounting on the bottom of rad., along with what else you posted.
Oh, yeah, might need new hoses and re-adjust trans lines.
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 01-05-2010 at 06:10 AM. |
Redneck Customs Bumpers, IA
you'll also need the lower rubber mounts for the thicker radiator the BB radiator should be a 4 core which the 400 sbc also ran the radiator hoses should be ok as long as the port sizes on the radiator are the same as your current set up but you may have to adjust the trans lines
#5 | |
http://67-72chevytrucks.com/vboard/s...66#post1839766
1987 350 TBI lowered 5/7 |
#6 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#7 | |
but those are the parts you need to do the conversion...save your money and dont buy the radiator from them, its like $250 or something, just get it from autozone, it was and still is, only around $160 or so, and if you know someone there, you can always get a discount ![]()
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 01-05-2010 at 11:39 AM. |
