What do yall think? 82 vs 94 silverado
Ok folks I am having a hard time deciding on what truck i want to keep. The two trucks in question are my 82 k10 long bed. And my 94 Silverado ext cab short bed. As for mods the 82 is lifted 4inches and riding on 35 Bfg AT's all about 6 months old. 350/700r4 as of now. The body is not in bad shape already have replacement panels for the rusted spots. If I go with the 82 I already have a 4speed complete setup to swap over.
The 94 is pretty much stock except the rear is a 14bolt sf and has an add a leaf. 5.7/4l60e. needs the transfer case swapped since it does not have 4hi, already have one though. Also the engine is kinda weak and wont idle down past 1500 rpm. needs rust repair on all 4 wheel wells, and one rocker panel. Has no carpet in the truck but everything else is in good shape. I figure both will get close to the same on gas mileage. 82 does about 8-9mpg now and not sure on the 94 but its pretty bad. I really just want a reliable truck that I can DD and if things do break are easy to replace and are cheap. Neither truck is a real looker so I am not really basing anything off looks. What would you all keep as a daily? any opinions on what you think would be better to hang on to? I know this might be a bit biased on this forum but I know many of the folks here have some experience with both trucks. Thanks for looking. |
Gettin It One Pice At A Time
Re: What do yall think? 82 vs 94 silverado
I would go with the 82. The parts availability is 20 years long, more specific 10 years for your truck. As apposed to 6? For the other truck.
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
Redneck Customs Bumpers, IA
parts are cheeper for the 82 by a long shot and they are also way easer to work on, 1 suggestion though, if you do a 4 speed swap spring the little extra dough for a good dual friction clutch from Clutch Masters or the sort, most clutched from the parts stores don't last, and I know after tearing the center outa 3 Advance Auto parts Premium clutches in 2 months in my 79 I won't by anything but a Clutch Masters clutch again ran one for 5 years befor I sold the 79 and am running one in my 83 currently, and I run a 91 Silverado extended cab longbox 4x4 in the summer so I can play with the 83 in the mud so I know the pro's and cons of each of the trucks
78K & 79C Jimmys
where i am the 82 sounds cheaper,no smog test,less computer stuff to deal with
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Ummm I like them both to be honest. Can we see some pics.
1979 GMC Sierra 15 1986 Danco Rollback 454 4spd 1986 Jerr-Dan Rollback 454 4spd 1978 GMC Jerr-Dan 454 Tonawanda 4spd FOR SALE 85 Chevy Wrecker 454 4spd AATAC Always a Friend...Michael ![]() |
It followed me home?
Keep the 82, 88-94 has to be the worst interior GM has ever had.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
No current pics of the 82, I am stuck in Iraq so they will be hard to get.
![]() ![]() ![]() ![]() these are the only pics I have of the 82, it is now lifted like I mentioned with black wagon wheels. Also the doors are black I wanted manual and the PS door was messed up. Sorry if the images are not sized well. |
Ok 1st off keep your head up bro. Second the room in the 94 is a lil better I agree. But I would keep the 82. Easy to work on and just a mean looking truck and sturdy.
It's kind of a toss up in my eyes too. Both being 4x4 is a wash. The 82 is more classic to me, but the 94 is ext cab so you would have more room. To me it really just comes down to what you are really wanting out of the truck. I personally think the 94 would be a better DD, and the 82 more of a play toy. I say keep both for those to duties.
#12 | |
#13 |
Still plays with trucks
The TBI motor and electronic trans in the 94 are very nice when they work right but with your idle problem you have some work to do. It should get 14+ mpg in good tune. The extended cab is nice to have and so is the canopy.
The 95-99 interior and dash can be swapped in there with no issues if you really don't like the earlier interior. The 82 is definitely easier to work on but being a regular cab and a long bed they are very different animals. With the bad transfer case added to the poor running engine in the 94 I would go with the 82 even with the worse gas mileage.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#14 |
dang its hot
then again, the money you would get out of the 82 would freshen up the 94.....hummm...or visa versa
#15 |
Resident of Here
Eighty Two!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#16 |
#17 |
#18 |
Crew Cut
on this board it will be keep the 82. if you want to keep the 94 ask the question over on the 88-98 board. any way good luck with your decision. joe
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
#19 |
If you want something for off road use,The 82 has a solid axle vs the irs the 94 has which will break off road.And I'm with most of them i like the 94 body style hate the irs and the interiors designed and the blue and red have no place in a truck.
#20 | |
By the way, unless that 14 bolt was actually swapped, it is factory. It was part of a Heavy-Duty Chassis Package available on the 1500s for the 88-98. I have a 95...includes gvw of 6600 (standard is 6200), engine oil cooler, 2nd external factory transmission cooler, bigger rear drive shaft, and some other stuff . . .
I think the 81-82 front clip really sucks....however the 92-94 interior wasn't all that bad...what sucked was the 88-91 with the white disc gauges. All in all, the 82 is now a classic vehicle, probably cheaper on insurance. I know my '77 is dirt cheap on basic insurance and plates....$45 for a year on plates and about $40 a month. Whereas my '95 is $79 for a year of plates and about $60 a month on insurance. Now I am not for sure, but the '82 MIGHT have the computer assisted carburetor in it...I know 83-84s had them. The 82 will probably be better if you don't end up needing the extended cab for storage/people transportation. Or sell them both and get something nicer in either year range. Quote:
Funny thing, my '77 3/4 ton with plow prep has a gvw of 6,300, and my '95 1500HD has a gvw of 6,600. Both are within a few hundred pounds dry weight too. So actually, if DOT ever checks up on me, I am better off with the half ton than the 3/4 ton. ![]() --It's all your choice, whatever rig you want to end up with. Personally, I like the '82 as it sat stock. Might end up taking my '77 down to stock, don't know yet. They perform better....it is silly using a 4" lift to gain 1 1/2" of ground clearance with bigger tires.....frame height doesn't matter when the axles are what gets hung up.
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson Last edited by ToughBowtieTruck; 01-05-2010 at 10:50 PM. |
#21 |
agh double posted.....I hate not being able to delete screwed-up posts on this forum!
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson Last edited by ToughBowtieTruck; 01-05-2010 at 10:49 PM. |
#22 |
Stock the irs is iffy once you lift it 6 inchs and run 38s or bigger then you have problems.
#23 |
Well reckon the 82 it is. Thanks for all the input folks I really appreciate it.
