wiring harness for 79 chevy
I think I will get a little more input here. What are you guys doing for a wiring harness for your trucks? I checked painless and it seems expensive. anybody else out there?
Chris |
6.0 powered square
Re: wiring harness for 79 chevy
I used a ez 2 wire http://stores.homestead.com/ez2wire/...GTO/Detail.bok
![]() ![]() hid all the wires in the engine compartment ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 01-05-2010 at 11:48 AM. |
how did you deal with the access through the firewall?
6.0 powered square
I used sheet metal to cover up the factory holes, and the wires go through the floor pan
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
yeller
I used Painless' kit...loved it!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
I installed a Ron Francis Express kit and i´m happy with it!Looks pretty wild in the pics but we took our time and the wires are labeled every few inches!
No rocketscience here just straight forward! ![]()
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ![]() ´81 GMC C 10, Spanish Red |
I just got back from my auto shop and they quoted me $400 for a 12 volt circuit and $600 for an 18 circuit. The catalog called for part number 10205 for my 79 the 18 circuit, but I only need a 12 circuit. there is a universal 12 circuit kit 10103. should this work? just do not want to waste $200
yeller
replied to your PM Chris.
Bottom line, the 18 circuit is a bolt in deal, no cutting, no aftermarket looking fuse block.
Slots go on anything!
A lot of it boils down to your plans for the truck. If it is going to stay stock, I would look at some of teh stock replacement harnesses from Brothers, LMC, etc. If you are planning on modifying a lot of things, then a universal harness would be the way to go.
1974 Jimmy- 5.3/4L80e/NP241 |
Crew Cut
look on the vendor page one of them had one on sale.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
I checked the page and it is the wrong one. I am going to call painless and see what they say. I have heard a lot of good things and they always use them on muscle car and those shows. so I plan to go that route just need to know what will work. no plans to add anything later, but have time to think about it. thanks
Chris |
