Old 01-05-2010, 10:56 AM   #1
kennystrickland
67 k10 lift kit
I have a 67 Chevrolet K10 LWB 4x4 that i am restoring and i would like to put a 4" lift kit on it but all of the kits i find say they will only fit 69-72, can anybody tell me why and what i can do?
kennystrickland is offline   Reply With Quote
Old 01-11-2010, 02:57 PM   #2
msgross
msgross's Avatar
Re: 67 k10 lift kit
The rear springs are different... they are longer on 67-68. You can do a diy4x.com shackle flip kit and then use 4" regular springs. Just be sure to measure spring eye to spring eye to make sure they work.
The shackle flip will require you to remove the rear shackle but that's only 4 rivets. I would also plan on new bushings in the rear and maybe a zero-rate or add-a-leaf if oyu need an extra inch due to sagging springs.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-12-2010, 03:50 AM   #3
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: 67 k10 lift kit
Do you know what size spring is on the rear? 56"? I have 68 swb and want lift, ord offers kits for 67-72 and cover different sizes. If I did an axle swap to disk in the future would the same springs in the front work?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 12-27-2010, 12:56 AM   #4
1malo68
1malo68's Avatar
Re: 67 k10 lift kit
67 and 68 used a 2-1/4" wide spring. 69-72 used a 2-1/2" wide spring
1malo68 is offline   Reply With Quote
Old 12-27-2010, 09:04 AM   #5
67gmcstepside
Re: 67 k10 lift kit
Mike, you have the heavy duty leafs on your 68? 3 Leafs and the width is 2 1/4? So I f I could find a 68 with your leafs they would be a direct bolt and give me a little lift?
67gmcstepside is offline   Reply With Quote
Old 12-28-2010, 05:18 PM   #6
msgross
msgross's Avatar
Re: 67 k10 lift kit
I'll double check the width... front springs should be the same on most trucks though... You could just add another leaf or install a zero rate leaf for 1" of lift. Also increase the shackle length (I have a set of 6" shackles you can have cheap)
The Garage:
Old 12-28-2010, 08:06 PM   #7
67gmcstepside
Re: 67 k10 lift kit
" Also increase the shackle length (I have a set of 6" shackles you can have cheap)"
Sounds good for the shackles. My drvs side is a little twisted and need to be replaced so might as well go with yours. As always thanks! PM me with payment info.
Old 12-28-2010, 09:32 PM   #8
Mxracer202
Mxracer202's Avatar
Re: 67 k10 lift kit
also check out the metal made rite: revolver shackle flip kit!!! just read some reviews on it and people say its top of the line. I am akso looking for a lift hopefully soon and I am considering these, and the DIY4x4 kit.
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
