Old 01-05-2010, 11:47 AM   #1
Collisionstudent
cross reference frame specs
Hi its me again thanks for all the help last time. I'm in need of your guys help again. Same truck 72 short wheel base looking for frame specs. Found some with search but I cant print them out big enough to read them. Also they do not have frame cross measurements. The truck was hit in the front and we are trying to pull it back, but I cant find the measurements. Thanks for any help that you can offer a student in need.
Collisionstudent is offline   Reply With Quote
Old 01-06-2010, 12:44 AM   #2
Rod
Re: cross reference frame specs
Courtesy of Rod
Though the spec picture shows a 1971 Blazer 2wd frame, the frame dimensions up front are the same on a 2wd Blazer as a 2wd truck.
4x4 are different specs FYI.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
