Old 01-05-2010, 02:36 PM   #1
Firebirdjones
Urethane transfercase mount??
Can anyone supply a part number?? I'd like to order this local from Napa or a place similar.
I already have a urethane torque mount,,,just need the main crossmember mount. Thanks.
Firebirdjones is offline   Reply With Quote
Old 01-05-2010, 03:17 PM   #2
drunkbus
New Member
drunkbus's Avatar
Re: Urethane transfercase mount??
Here you go. It took about 30 seconds to find if you just try.
http://www.summitracing.com/parts/ENS-3-1106G/
drunkbus is offline   Reply With Quote
Old 01-05-2010, 03:30 PM   #3
Firebirdjones
Are you kidding?? I spent 1/2 hour on here trying to find it on Energy Suspensions website to no avail. I hate these damn computers
Old 01-05-2010, 04:48 PM   #4
Thealien
Thealien's Avatar
here they are at their own website
Mounts
and the
TORQUE MOUNTS
Old 01-05-2010, 04:56 PM   #5
drunkbus
New Member
drunkbus's Avatar
Mounts
and the
TORQUE MOUNTS
Even better yet. I don't know how to get fancy and change the links.
Old 01-05-2010, 04:59 PM   #6
Thealien
Thealien's Avatar
When you add the link in the box and hit OK, hit enter and then type in whatever you want. Sometimes its better than the long link it ends up being!
Old 01-05-2010, 05:58 PM   #7
swyfor5
swyfor5's Avatar
Got mine from LMC. A little pricer though, $69.95. Ones they sold me were made by PROTHANE. Look identical to those from Summit.
swyfor5 is offline   Reply With Quote
Old 01-05-2010, 07:01 PM   #8
Firebirdjones
Ah yes,,,,thankyou. Prothane was the other name that was escaping me.
Old 01-05-2010, 07:03 PM   #9
Firebirdjones
Mounts
and the
TORQUE MOUNTS
Thanks, wish I knew how to do that. I'm terrible at searching
Old 01-05-2010, 07:08 PM   #10
Thealien
Thealien's Avatar
It was easy for me only because
I've been there done that
Old 01-05-2010, 10:01 PM   #11
jaros44sr
jaros44sr's Avatar
Be careful on the torque mounts, make sure the bolts fit the spacers well. I ended up calling them and getting new ones, I forget what the part number is, but you will see a big space between the bolt and the spacer if you have the wrong ones. When I talked to customer service, he said no one ever complained in 15 years the part has bin in production
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-05-2010, 11:10 PM   #12
Firebirdjones
Thanks for the heads up. I'll have to check it out. I haven't even opened the package for the torque mount yet. Since I don't have the main transfer case mount in my hands I figured I'd just wait until then, and do it all at once.
Old 01-06-2010, 09:08 AM   #13
Thealien
Thealien's Avatar
Were the bolts to big or small? What was the discrepency? Leave it to you to get the one in 15 year odd duck, should have used that luck on a lottery ticket!
Old 01-06-2010, 04:58 PM   #14
jaros44sr
jaros44sr's Avatar
Yes and yes, depending how you look at it It seems that their engineering department thought we had 1/2" mounting bolts, but in fact they are 5/'8"(not sure of the of the exact demensions), so you need to ask them for the correct spacer. Seems like everyone was happy with the slop for the past 15 years
Hope this helps, not very good at splainin' things!
SAFETY FIRST
AS usual, off topic
Jim
Old 01-06-2010, 06:04 PM   #15
Thealien
Thealien's Avatar
Nope now I am really confused. If they thought our bolts were 1/2 (4/8ths) and are actually 5/8ths I would think they wouldn't even fit through the spacer let alone be loose?
Old 01-06-2010, 07:17 PM   #16
jaros44sr
jaros44sr's Avatar
That's why I said "not sure of the actual demensions". Bolts are 1/2" OD ,spacers are 5/8"ID. Any better? as I say not sure what it was, but considerable space, not the example I used above
Still confused?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-06-2010, 11:24 PM   #17
Thealien
Thealien's Avatar
I could always look at my mounts and bolts? But then I "may" have to make a call and its all your fault!
Old 01-07-2010, 01:45 AM   #18
jaros44sr
jaros44sr's Avatar
Depends if you are comfortable with the slop, I wasn't. Must've bin the Machinist in me
Don't shoot the messenger
SAFETY FIRST
AS usual, off topic
Jim
Old 01-07-2010, 09:01 AM   #19
Thealien
Thealien's Avatar
Never liked a loose fit if you know what I mean.
