01-05-2010, 06:09 PM | #1 |
It followed me home?
tire help for rally wheels
I've been searching for a couple hours and cant seem to find exactly what I am looking for so here we go again.
My blazer lowered about 5-6" (3" spindle, spring, big block) front with van rally's (8" truck rally's rub a ton dont want to grind any more) and flip kit rear 8" truck rally. I need to pick some tires to run on my rally's until I find some larger diameter wheels I like. I want as wide a tire as I can get in the back to help with traction and I also like the look, the front I dont want any rubbing issues at all. Currently I have 235-60 fronts and 295-50 rears but the front are just too short , looks like I need to replace all four because anything taller in front will be taller than the 295's in the rear. Suggestions? pictures of your setup would be great, thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-05-2010, 06:48 PM | #2 |
6.0 powered square
Re: tire help for rally wheels
so are you saying your still running van rallies then 215/70-15 front and 275/60-15 rear
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
01-05-2010, 07:54 PM | #3 | |
I was thinking maybe a 235-70 front and 275-60 rears, I dont want the front to look to narrow escpecially after they are tucked in another inch from the van wheels EDIT: typed wrong tire size
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-05-2010 at 08:08 PM. |
01-05-2010, 08:06 PM | #4 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-05-2010 at 08:08 PM. |
01-05-2010, 08:31 PM | #5 |
Truck Nut
On my dropped 87' burb I run a 7" truck rally with a bfg 225/70 and on the rear a 8" rally with a bfg 275/60. Front tire is less than an 1/2" shorter than the rear.
Tony Kee Texas Square Bodies |
01-05-2010, 08:32 PM | #6 | |
I know the pieces fit
EDIT: I never said what drop the truck has. Summit (Ground Force) 3" front springs, new factory rear springs from Husky with a 2" shackle drop. The rake is not nearly as extreme as the picture shows, the truck was parked on a low spot or something. It does have a bit of rake, but where the truck was parked for those pictures makes the rake look a whole heap more than it is. Last edited by 68Timber; 01-05-2010 at 08:59 PM. Reason: making excuses for a bad look |
01-05-2010, 08:49 PM | #7 |
67-72 parts collector,…
Here's my old '82.
15x7 and 15x8 ralleys. 215/70-15's and 275/60-15's. Approximately a 4"/5" drop. |
01-05-2010, 11:57 PM | #8 |
Thanks for the pics guys, I think I'm going to have to raise the front of the truck another inch or so. It sits way too low right now for a 26" tire, I think I'll order the tires and see how it sits with them mounted up before I try changing anything. The O.D. of the 15" will be really close to what a 20" will be so I shouldnt have to change anything later.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-06-2010 at 12:18 AM. |
01-06-2010, 11:49 AM | #9 |
I have 285/70 and 235/70 15,s n my blazer,I have bags in the fr and a flip in the rear with a 1in block
01-06-2010, 02:55 PM | #10 |
wow! whered u find 285/70's? i love those!
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
01-06-2010, 06:41 PM | #11 |
I 2nd that your blazer looks killer good work !
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
01-07-2010, 12:12 PM | #12 |
I got them bf goodrich,I know some of you say you can,t find them but there still out there,alot of guys use them on their roadsters
01-07-2010, 12:49 PM | #13 | |
http://store.coker.com/285-70r15-bf-...blackwall.html
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-07-2010 at 12:50 PM. |
01-07-2010, 01:46 PM | #14 |
Slots go on anything!
Coker is also showing a 285/60 Radial T/A that is 29.5" tall and will fit an 8-10" rim.
1974 Jimmy- 5.3/4L80e/NP241 |
01-07-2010, 02:47 PM | #15 |
They make a 285-60-16. I didn't see a 285-60-15.
01-07-2010, 03:08 PM | #16 |
You're entirely right. I was ready to keep my rallies for a little bit, too. Oh well.
01-07-2010, 08:34 PM | #17 |
front:205/70/15 with van rallies(5" drop)
Rear:235/75/15 with 7"s (6" drop) |
01-07-2010, 09:24 PM | #18 | |
I think the best most reasonable option for what you are looking for would be: BFG Radial T/As 225/70 up front in back a 285/70 Radial T/A, Which, like Scoti said, is now manufactured by Coker under the name Silvertown--and they are pretty proud of them. Other than that it's either what you've got or 275/60
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
01-07-2010, 09:35 PM | #19 |
i know this one has 205/70/15 on the front with van rallies and 275/60/15 on the rear with 8"s
01-07-2010, 09:51 PM | #20 |
adam-check out these rallies I found online.
01-07-2010, 09:59 PM | #21 |
01-07-2010, 10:09 PM | #22 |
I don't know anything about those rims. I found them online awhile back and saved the pics.
www.ratrodstudios.com |
01-07-2010, 10:56 PM | #23 | ||
Those are kind of cool, not my style but I do like them
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-07-2010 at 10:58 PM. |
01-07-2010, 11:18 PM | #24 |
