Old 01-05-2010, 06:13 PM   #1
cochino12
It followed me home?
cochino12's Avatar
How much can I grind off?
How much can I gring off my lca to help clear my 8" rally wheels? If anyone can take a picture of how much they took off it would help me a ton, thanks
related post
http://67-72chevytrucks.com/vboard/s...d.php?t=379588
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-05-2010, 06:32 PM   #2
grinch4om
dang its hot
grinch4om's Avatar
Re: How much can I grind off?
I wouldn't...I would find 7" van ralleys, put the same trim ring and center on that wheel and be done...that's what I did and you have to really look to notice
grinch4om is offline   Reply With Quote
Old 01-05-2010, 08:10 PM   #3
SCOTI
SCOTI's Avatar
IIRC, the 8" wheels have 4" back-spacing & the 7" wheels are like 3.75". So there's not much difference toward the a-arm.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2010, 08:21 PM   #4
OJOE
Crew Cut
OJOE's Avatar
and that 1/4 " diffrence is what you need. good luck, joe
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-05-2010, 08:23 PM   #5
texassquarebodies
Truck Nut
texassquarebodies's Avatar
I cut off about 4 " inches of the lip off. Front and rear on the lower A arm. I cut it smooth and blended the sharp edges. Been like that for years. Did it to my dad's truck also. No problems. Might need to grind the ball joint area as well for 8" rallys. Also, 8" rally's should have 4.5" B.S and 7" have 3.75". I have 7" truck rallies on my burb with dropped spindles. No cutting at all. Plenty of clearance.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 01-05-2010, 08:29 PM   #6
cochino12
cochino12's Avatar
any pictures? I'm not sure how deep into the lip I can go. thanks for the info
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-05-2010, 08:43 PM   #7
1LowToy
My guess is I'm going to be having the same problem when I do mine. Is it the 275/60 tire rubbing, rim or both?
1LowToy is offline   Reply With Quote
Old 01-05-2010, 08:58 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's the only picture I have.
The blue tape shows the area that is already trimmed.
(blue line shows how I cut up the bumpstop area)
I agree,... find some 7" ralleys to help the wheels clear the a-arm and the outer edge of the wheelwell opening.
But I always trim them anyway,... in case you want or have to throw an 8" ralley wheel on there.
Old 01-05-2010, 09:03 PM   #9
lolife99
lolife99's Avatar
A 15" rim with 4 inch backspace (like a 15x8 truck ralley) is the problem.
Any 15" rim with 3.5" backspace will be fine.
Nothing that a grinder can't easily fix.
Old 01-05-2010, 11:53 PM   #10
cochino12
cochino12's Avatar
Keith you are the man!! Looks like I still have more to trim, I really dont want to use the van wheels unless I have to. Thanks
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-06-2010, 12:10 AM   #11
lolife99
lolife99's Avatar
Hey Adam,...
If you have a bare 8" ralley,... bolt it up after you trim the a-arm, (with the weight of the truck on it), and rotate the rim with the wheel turned full lock left and right.
Also look for wheel weight interference after you get your tires installed.
I still like 7's up front since the track width of these trucks are wider in front.
Old 01-06-2010, 12:24 AM   #12
1LowToy
Are you saying to cut away all that blue taped area aroung the ball joint?
Old 01-06-2010, 12:25 AM   #13
bigblock73
yeller
bigblock73's Avatar
No, he is saying that is the area that was cut...you can see how the arm steps up in that area...that is the trimmed off area.
bigblock73 is offline   Reply With Quote
Old 01-06-2010, 12:25 AM   #14
cochino12
cochino12's Avatar
I dont think so, if you look at the lip you can tell that the part that is taped has been trimmed. Did I describe that right?
EDIT: Jeff beat me to it
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-06-2010, 12:34 AM   #15
lolife99
lolife99's Avatar
I just put the blue tape on there to show the area that was trimmed.
(since I didn't have a picture of a stock a-arm to compare it to).
Old 01-06-2010, 12:40 AM   #16
1LowToy
Like from the inside edge of the ball joint out? On the side of the LC of course
Old 01-06-2010, 12:48 AM   #17
lolife99
lolife99's Avatar
yes.
Old 01-06-2010, 12:54 AM   #18
lolife99
lolife99's Avatar
In this picture,... it's the red lines that are the area of concern.
I also trim up the bumpstop bracket,... but that's up to you.
Old 01-06-2010, 01:07 AM   #19
mailman
mailman's Avatar
in this picture,... It's the red lines that are the area of concern.
I also trim up the bumpstop bracket,... But that's up to you.
i had to remove my bumpstop bracket for a lower bag plate mount.will this hurt any thing?
mailman is offline   Reply With Quote
Old 01-07-2010, 08:46 PM   #20
low86c10
6.5" van rallies work
low86c10 is offline   Reply With Quote
