Old 01-05-2010, 06:30 PM   #1
sierragrande71
sierragrande71's Avatar
Cutting rear coil springs?
I was wondering if its possible to cut a coil out of an already lowered spring? Without ruining the integrity of the lowered spring? The rear coils on the back of my '69 c10 are dropped 4inches and the back end is a little too high for my liking. Any feedback would greatly appreciated. Thanks
sierragrande71 is offline   Reply With Quote
Old 01-05-2010, 06:46 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Cutting rear coil springs?
not possible to cut rear springs.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-05-2010, 07:00 PM   #3
sierragrande71
O ok then that eliminates that LOL! I guess I'll just have to pony up and buy some more springs then! Thanks leddzepp for the quick response!
Old 01-05-2010, 07:28 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Take the torch to em!!!
jk
John
1999 Toyota Tacoma 4x4
Old 01-05-2010, 07:33 PM   #5
LowBow
Self Made Hundredaire
LowBow's Avatar
Just put a lowering block between the trailing arm and rear end. Viola, lower truck.
'79 corvette - all original 49k car!
'03 Z71 ECSB - gas hog
'57 Belair 2 door hardtop. Love of my life!
LowBow is offline   Reply With Quote
Old 01-05-2010, 07:36 PM   #6
scrapmetalart
Junior Member
there you go
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-05-2010, 07:40 PM   #7
71swb4x4
71swb4x4's Avatar
To clarify both the top and bottom of the rear springs are pig-tailed. The pig-tail is what allow you to bolt them to the frame and the trailing arm. If you cut a pig-tail off you wouldn't be able to attach the top or bottom of the spring.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-05-2010, 07:47 PM   #8
sierragrande71
Any clue where I can find lowering blocks? Roughly what 's the cost of them? Thanks.
Old 01-05-2010, 08:03 PM   #9
71swb4x4
71swb4x4's Avatar
Make them yourself, or have a machine shop make them. Probably around $40 a pair. You will need longer u-bolts, maybe $30 a pair for those. I am sure you can find both for cheaper if you know the right people.
Old 01-05-2010, 08:15 PM   #10
Shane
Shane's Avatar
Here ya go ... http://www.classicperform.com/6092chevtrk.htm
scroll down towards the bottom
Shane is offline   Reply With Quote
Old 01-05-2010, 08:25 PM   #11
mbgmike
Thats what I would do. We can sell you a set of lowering blocks but its a lot less expensive to make your own. I once made a set out of Trailer hitch reciever type insert for a 1" reciever on a foreign car. They were in the $1.00 clearance box at a dept store. Just cut off the crooked part and used the straight section. drilled one hole per bar. It already had a hole for the pin. They were Galvanized to. $2.00 plus state tax
mbgmike is offline   Reply With Quote
Old 01-05-2010, 09:03 PM   #12
cdowns
cdowns's Avatar
before installing lowering blocks make sure you get the longer ubolts that you need
