Tme for a new tranny... 700r4 questions
I changed the fluid in my TH350 today, it had enough copper in the pan to make a new penny! I noticed the tranny slipping awhile ago...anyway I'm going to go with a 700r4 but what type?? Lock-up, non lock up, computer controlled.... I 've got a carbuerated 71- 3/4 ton long bed. I need some suggestions and some help- I tow my 67 firebird drag car to the track alot so the tranny has to be strong... Thanks for the help
Heres a place that might help you out. WWW.JETCHIP.COM good luck
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I would suggest doing a search of this site. This topic has been covered a lot. Good luck!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
I build my own but if you dont go here...
www.700r4.com Very good heavy duty parts that will hold up to towing. I use a lot of their stuff.
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
newly minted old timer
just do it right, get the best one possible and be sure to put it in perfectly. there is no room for errors.. i dont like them for that reason.
when they work they are aswome. but the fail rate on these are way to high.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
its all about the +6 inches
Also, since you tow or a regular basis, talk to a good tranny rebuilder. These things are not known for living very long when the trailer hitch is used alot.
