Old 01-05-2010, 10:01 PM   #1
72longbed
72longbed's Avatar
Question Axle Width Question?
Who can tell me the difference in overall width (WMS to WMS) between an 8 lug Dana 44 front axle (Big Spindle, Disk Brake) and an HO72 rear axle (8 lug 9/16 studs, leaf spring type)??
I'll bet a few of my fellow 4x4 enthusiasts know this info as well as their wife's birth date? LOL!! (maybe better?)
Thanks,
72longbed
72longbed is offline   Reply With Quote
Old 01-06-2010, 07:55 PM   #2
yellow70GMC
yellow70GMC's Avatar
Re: Axle Width Question?
should be 3 inches
yellow70GMC is offline   Reply With Quote
Old 01-06-2010, 08:01 PM   #3
72longbed
72longbed's Avatar
Question Re: Axle Width Question?
Yellow70,
Thanks, where do you get your numbers to know that there is a 3 inch difference? I can't seem to find any data on the measurements I'm looking for.
Thanks,
72longbed
Old 01-08-2010, 04:44 PM   #4
yellow70GMC
All the straight axle chevy trucks from 67-91 have a 3" difference between the front and rear axles. You're talking about total track width from lug surface to lug surface, correct?
Old 01-08-2010, 04:46 PM   #5
yellow70GMC
I'm also assuming that an HO72 is the same width as the 12 bolt, 14 bolt, and 10 bolt. I could be wrong, i've never owned a truck with an HO72. But the 12b, 14b, and 10b are all the same.
Old 01-08-2010, 04:56 PM   #6
72longbed
72longbed's Avatar
Ok .... so what is that width of the front or rear or both? Is it 65", is it 68"?
I'm looking for a printed guide to the Dana HD 44 1971/72 that specs the WMS (wheel mounting surface) width. It would also be good to find a similar resource for the HO72 and HO52. I have an HO72 under my truck but I don't know what it came out of. It's not stock to my truck.
I guess I could try to get an accurate measurement from under the truck once we get out of this deep freeze we're having here.
I want to make the rear axle wider with spacers/adapters so it is the same width as the Dana 44, and need to know what thickness I'll need in the rear.
Thanks,
72longbed
Old 01-08-2010, 06:52 PM   #7
b454rat
Fronts are usually 69" or so, rears are aboot 65". Get a rear from a van, same width as the front.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 01-08-2010, 07:14 PM   #8
72longbed
72longbed's Avatar
Thumbs up Re: Axle Width Question?
Thanks b454rat ... but I won't be changing that rear. I'm one of the old school'er types who knows that the HO72 is about a bullet proof as you can get from a factory rear. With the locker in there, and the matching ratio to the HD Dana 44 up front ... I'm happy. I will make it a bit wider to fill out those wheel wells out back.
I'll do some more research to see if I can find a list of GM axle widths somewhere?
72
Old 01-08-2010, 07:30 PM   #9
b454rat
http://77cj.littlekeylime.com/Dana44.htm
Its somewhere in here, can't remember where. But most GM axles are either 67" for 1/2 or 69" for 3/4 and 1 ton.
Old 01-08-2010, 10:55 PM   #10
yellow70GMC
You could use wheel spacers on the rear to make up the difference, i've known a few people who have used 1 1/2 spacers on each rear wheel and it looked perfect. The only problem is it will put additional pressure on the outer wheel bearings.
