Old 01-05-2010, 10:54 PM   #1
3r!c84
Badass
3r!c84's Avatar
2nd gear face plant
ok when im getting on it.run threw first gear gets about up to 3k and u hear the primary's kick in and then it shifts at 43xx and then just falls flat on its face and slows down then gets back in it????????????
its a stock 305 with a quardajet
with a th350
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-05-2010, 11:30 PM   #2
83_Stepside
Re: 2nd gear face plant
i've been having the same problem since i bought this truck a few months ago. i have a 700r4 though. i havent figured it out either.
83_Stepside is offline   Reply With Quote
Old 01-06-2010, 03:11 AM   #3
Matt Man
Matt Man's Avatar
fuel pump?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-06-2010, 04:58 AM   #4
madcow75
madcow75's Avatar
Mine has been doing the same also factory 305, th350. I was low on tranny fluid put some in and it has been good for a while but it's back again. Could it be dirty oil, filter or a vacuum problem? I haven't looked into it. Household work truck.
madcow75 is offline   Reply With Quote
Old 01-06-2010, 06:34 PM   #5
big10ratrod77
big10ratrod77's Avatar
yea my 77 dose that idk the rpms but when you get the four barrol open in
2nd and are pulling bout 75 mph it just dies then you shift and then it pics rite up ill you hit about 110 or so and it dose it again mines a 350/sm465/3.73s i was gonna rebuild it sooner or later and was gonna try a bigger needle and seat
BUT... i can say 1 thing back when my carb wont adjusted (it was about 6 turns out on each side) it would pull hard past 100 and start climbing towards 0 all this happened when i had my carb adjusted
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 01-07-2010, 08:45 PM   #6
low86c10
mine used to do that and i put a edelbrock 650 on it and got rid of all the extra vacumm lines a junk and it runs great now, not bad for an old 305
low86c10 is offline   Reply With Quote
Old 01-07-2010, 08:55 PM   #7
3r!c84
Badass
3r!c84's Avatar
what intake are you using?
-00 Saturn 5spd
1/4:13:90
Old 01-07-2010, 09:23 PM   #8
low86c10
stock
Old 01-07-2010, 09:28 PM   #9
3r!c84
Badass
3r!c84's Avatar
how can you fit that carb on a qjet style intake?
-00 Saturn 5spd
1/4:13:90
Old 01-07-2010, 09:30 PM   #10
low86c10
adapter plate
Old 01-07-2010, 09:32 PM   #11
low86c10
i think i used this one
http://www.summitracing.com/parts/ED...odel|Performer
Old 01-07-2010, 09:33 PM   #12
3r!c84
Badass
3r!c84's Avatar
ohhhh u shoulda got a intake off of CL they are cheap like 50$ at the most
hell i got a preformer RPM airgap for cutting my friends grassbut im still looking for a carb
-00 Saturn 5spd
1/4:13:90
Old 01-07-2010, 09:38 PM   #13
low86c10
i actually had one i got for $50 and my little brother tried to pick it up and dropped it and it cracked and i already had the adapter in the garage from an another car so i just used it when i ever clean my enginebay up i will prolly get me a new intake
Old 01-07-2010, 11:27 PM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
It could be the fuel filter or fuel pump. Mechanical or vacuum secondaries?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-07-2010, 11:28 PM   #15
3r!c84
Badass
3r!c84's Avatar
vacuum secondaries
i could change the fuel filter thats in the carb.it dont have one any where else
-00 Saturn 5spd
1/4:13:90
Old 01-07-2010, 11:30 PM   #16
low86c10
vacuum secondaries
you should have another one, that might be your problem
Old 01-07-2010, 11:31 PM   #17
3r!c84
Badass
3r!c84's Avatar
unless theres one under the truck.its all stock like this
-00 Saturn 5spd
1/4:13:90
Old 01-07-2010, 11:38 PM   #18
low86c10
yea i think its on the inside of the drivers side frame rail
