01-05-2010, 11:28 PM | #1 |
1972 3/4 Ton Rear Suspension
I am traveling to look at a 1972 Stepside pickup for an upcoming project. The owner thinks it is a 1/2 ton but is not sure. He provided me with the vin number which revealed that it is a 3/4Ton. I am looking for a 1/2 ton and want the trailing arm suspension.
My questions are before I drive for 8 hours: Does the 3/4 ton have the trailing arm suspension or is it leaf springs? Are the front spindles different between 3/4 and 1/2 ton vehicles? Are 8 lug wheels the quick and easy way to identify a 3/4Ton? I have asked for pictures but they seem slow in coming. I do appreciate any information that will help me identify the truck. |
01-06-2010, 01:03 AM | #2 |
Re: 1972 3/4 Ton Rear Suspension
5 or 6 lug=1/2 ton, 8 lug= 3/4 ton , they did make 3/4 ton with trailing arm suspension, but I think more common would be the leaf spring for the 3/4 ton ask him if there is any badges on the fenders that would indicate C/10 or C/20 C/20 would be 3/4 ton C/10 would be 1/2 ton. Being thats it is a stepside, it is most likely (one would hope) a C/10 shortbed, or it may be a 3/4 ton longbed stepside .....
72 C20 Longbed 05 1500 Z71 |
01-06-2010, 01:06 AM | #3 |
i got a donor 70 1/2 ton short beb fleet side
01-06-2010, 08:29 AM | #4 |
Thanks for the input. I will check badging Sleepertruck 72 and also keep you in mind geremy should things work out and I need any parts.
01-06-2010, 10:05 AM | #5 | |
Middle-aged Curmudgeon
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
01-06-2010, 08:59 PM | #6 |
1968 C20 Vortec Beast
Many 3/4 ton have a coil/trailing arm suspension.
Ugly or not it still kicks a**! |
01-06-2010, 10:23 PM | #7 |
Junior Member
My '67 C-20 was a long bed stepside with trailing arms and coil springs when I bought it. It also had the over-load leaf spring behind the rear axle.
Normally Chevys had coil springs and GMC had leaf springs, any thing different were optional. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
01-06-2010, 10:32 PM | #8 |
3/4 tons have way heavier duty trailing arms, too. They're better for hooking up, and withstanding the abuse.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
01-07-2010, 11:49 AM | #9 | |
its all about the +6 inches
Most likely it has a coil rear. The frame is the same as a 1/2 ton. Very easy to convert |
01-07-2010, 10:27 PM | #10 |
I thank you all for the information. I am encouraged that this potential purchase might just work out. I know I want to end up with a 72 Chevy Shortbed with Trailing Arm Suspension. Hearing that a 3/4 ton has stronger trailing arms is icing on the cake.
I have inquired of the current owner for badging, and confirmation of trailing arms. If the vehicle meets my requirements and a price can be agreed upon, I will post some before pictures. Again, thank you for the information. |
