Old 01-06-2010, 02:11 AM   #1
mike14_07
mike14_07's Avatar
Dropmember and body drop questions
I have decided to go with a dm on my 68. my question is if i use 73-87 lca and my 68 uca, which nate said i can do, do i just put a 68 ball joint in the 73-87 lca? this set up will be just until i afford his tubular ones. and how are tall routing your brake, fuel, and trans lines? pics if you got em. i also what do i do about the the steering shaft? i seen a few home made brackets, but does the kit come come with one? also how would i go about lowering the body 1"?
mike14_07 is offline   Reply With Quote
Old 01-06-2010, 01:57 PM   #2
m6z
m6z's Avatar
Re: Dropmember and body drop questions
Use whichever year lower balljoint your spindles are for.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 01-06-2010, 11:36 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
This might get a better response in the "suspension section".
I'll see if I can get it moved,... if you don't mind.
Old 01-06-2010, 11:52 PM   #4
SCOTI
SCOTI's Avatar
When you order your DM, check w/Nate on the body drop. He should have a 'kit' that has everything you need.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-07-2010, 08:45 AM   #5
lolife99
lolife99's Avatar
Check out some of the "build" pics on Nate's website.
http://porterbuiltstreetrods.com/site/
