01-06-2010, 03:25 PM | #1 |
radio install question
how are you guys installing your stereo's.right now my truck has a old 2 nob style pioneer and i want to install new style radio.my dash is in perfect shape and not cut up do they make a dask kit or do i just cut the factory opening bigger.
01-06-2010, 03:55 PM | #2 |
Slots go on anything!
Re: radio install question
You will have to cut the opening bigger.
1974 Jimmy- 5.3/4L80e/NP241 |
01-06-2010, 04:24 PM | #3 |
dont cut the dash. go to retrosound.com and look at there modern units that will fit our dash. They are quality peices and look great
01-06-2010, 04:25 PM | #4 |
www.retrosoundusa.com that is
01-06-2010, 04:37 PM | #6 |
Unfinished Project Club
I agree, dont cut the dash get the new radio
Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas 1993 Jeep Cherokee. Looking for a swb chevy 73-87 |
01-06-2010, 04:40 PM | #7 |
i really dont want to cut it,how are the radios that lmc truck sells i think they are made by custom auto sound and is the quality of retro sound radios good.
01-06-2010, 05:12 PM | #9 |
It depends on how you look at it. My truck has been pretty well cut up already, so I figure cutting the dash is the least of my worries.
01-06-2010, 05:14 PM | #10 |
I'd just cut the dash. Done it to all mine. It's not like these trucks are highly sought-after collectables like a split window vette or a 2 door bel-air. besides why do you want your radio in the glove-box where you can't reach it or have a knob radio that requires a cd-changer to use cd's
If you really want to have a stock GM faceplate in the dash, you can send off the OE GM radio to have new guts put in it. Then it will look perfectly factory, but have a digital tuner, etc inside and they can even add inputs (Ipod) and outputs for amps, etc. Last edited by 78 Chevyrado; 01-06-2010 at 05:20 PM. |
01-06-2010, 05:26 PM | #11 |
Agreed. Even if you do cut the dash, it's nothing that a welder and a scrap piece of steel can't fix down the road.
The problem is that every time somebody puts a 1 DIN head unit into one of these trucks, they surface mount it or build some silly trim plate that looks like hell. If you take a few minutes to set the radio back in the opening and build a trim plate that fits snug to the radio faceplate, it'll look like it was meant to be there. Exibit A: The radio in the truck when I bought it: And exibit b: The radio I installed: To do this properly, you need to build a mounting plate and attach it to the backside of the dash so that the radio sits back a little bit. Since the previous owner hacked my dash up good, this was pretty much my only option anyway. Depending on your specific radio and how "flush" you want it, you can use washers to set the mounting plate back deeper. Mounting plate: mounting plate installed in my hacked up dash: |
01-06-2010, 05:32 PM | #12 |
You won't have to cut your dash if you get one of these ol'skool tape deck from alpine, you just buy the tape adapter at wal-mart (10 bucks) and plug in your zune or ipod, and your good to go...
GROUND ZERO IS R LIMIT |
01-06-2010, 06:00 PM | #13 |
Gettin It One Pice At A Time
It really depends on what you demand out of your audio experience, if your happy with just radio. Then the Retro sound is for you. If you demand anything much more then that, then get a newer radio.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
01-06-2010, 06:43 PM | #14 |
Retro sound vs Custom Autosound is a topic thats been discussed a lot. I have heard quite a bit of negative feedback from Custom Autosound but none from retro and I have retro in my 1950 gmc. Retro does not have a tape deck or cd player but it does have hookups for a changer or usb port and also have a jack on the front to easily plug in your Ipod or MP3 player. I personally dont listen to cds that much and if I want mor that just a radio I plug in my Ipod. Sound is great also. I think mine was just over 200 with the trim plate and custom knobs. It offers a cleaner install and dont have to worry about cutting the dash.
01-06-2010, 07:08 PM | #15 |
I tried to put a modern stearo in my truck and to say the least it really looks like hell .I'm really ashamed of how it turned out.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
01-06-2010, 08:17 PM | #16 |
If you just want to go with front aux in and pre-out, Dual makes a shaft head unit that ain't too bad. $40 from Amazon or Crutchfield. That combined with my iPhone (mp3's, Pandora, Pocket Tunes = Howard Stern) an active crossover and a couple of amps, I'm a happy camper and there was no hacking involved.
Here is a pic when I was installing and doing other dash related things about a year ago.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf Last edited by Oilbrnr; 01-06-2010 at 08:19 PM. |
01-06-2010, 08:31 PM | #17 |
that looks cool. but isn't that a DBL Din radio? did you have to cut your bezel?
01-06-2010, 08:37 PM | #18 |
just take and cut horizontal lines above and below the original radio holes. The plastic dash itself will need to be cut, but boo hoo. As for the truck dash just just lines like I said and bend the original holes in.
Then, if ever needed, bend the tabs back out and spot weld the cuts shut. That is how I install my CD players.
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson |
01-06-2010, 08:56 PM | #19 |
Redneck Customs Bumpers, IA
you can always get a din and 1/2 dash bezel and chunk of dash out of a 88-91 K5 or Suburban and aftermarket mounting kit and make it look real clean too, or even just mount a larger deck. (I plan on eventually mounting a retractable touch screan dvd-deck in my factory sterio location and using the spair bezel out of my 89 K5 to do so
01-06-2010, 09:04 PM | #20 |
GM Addicted
i just cut out my dash and my carriage for the deck is mounted on the plastic, they do sell an install kit for these trucks i have one but got it after i cut the hole, with the install kit it you still have to cut out the metal on the dash, and trim the piece a little to get it to fit rite go to sonicelectronix.com and they have the install kit on there and all orders over $10 have free shipping.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-06-2010, 11:22 PM | #21 |
my bosses truck had an after market din sized radio in it when he bought it, he wanted an original looking radio from custom auto sound. i had to make a mounting plate that covered up where the last owner hacked the dash up. ill have some pics of it the next time i can. but we are both happy with the quality of the radio.
and this is what my truck is like now: the last owner put this in, doesnt bother me tooo much yet, but i only drive the truck about once a week |
01-06-2010, 11:45 PM | #22 |
hello,just wanted to say if u cut it there is no return,depends on what you are doing with truck
01-06-2010, 11:49 PM | #23 | |
01-06-2010, 11:54 PM | #24 |
There is two special radios that will fit the factory hole but no cd player.Its better to cut the dash and mount a din size its cheaper you get a cd player and sounds better.crutchfield has a plate for 20 bucks it covers the hole and helps you know where to cut.
01-07-2010, 12:07 AM | #25 |
In the Forgotten far North.
I moved my switches for the rear window/aux heater/rear defroster to where my stereo was and also installed a 1/2 DIN DVD player under them and moved my stereo into an overhead console
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
