01-06-2010, 10:15 PM | #1 |
? about trailing arms
Why are the trailing arms kicked up in the rear?
01-06-2010, 10:52 PM | #2 |
Happy to be here
Re: ? about trailing arms
To make them parallel to the ground? Is this one of those "Why did the Chicken cross the road" type questions..
01-06-2010, 11:00 PM | #3 |
No chicken question. When I was making my trailing arms for my 56, (which are straight), someone told me that if they were not angled up I would have vibration in my drive line. My arms at ride hight are level to the ground. I didn't think it mattered, but before I finish everything up I thought I'd ask.
01-06-2010, 11:19 PM | #4 |
itsta correct pinion angle yo!!! lol
01-06-2010, 11:21 PM | #5 |
67-72 parts collector,…
You need to correctly set your rearend pinion angle to keep all the vibration in check.
01-06-2010, 11:33 PM | #6 |
someday it will be done!
I agree with the pinion angle issue,but why not make them a straight arm and clock the saddles to compensate?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
01-06-2010, 11:34 PM | #7 |
Hollister Road Co.
Its for the spring mounts. The springs need to be 90* to the frame otherwise you get a real goofy ride. You can mount the axle on an incline plain just turn the nose down to the correct angle and use coil overs behind the axle.
01-06-2010, 11:50 PM | #8 |
you're right.Looking at a bad angle pic of that area of my truck I didn't think the spring sat on the kicked up area,but after looking closer it does .
01-06-2010, 11:56 PM | #9 |
I won't set my pinion angle till my motor and trans is in, and sitting at ride hight. Then weld my saddles in place.
01-06-2010, 11:57 PM | #10 |
Also I'm on bags
