Old 01-06-2010, 10:18 PM   #1
ed2552
ed2552's Avatar
Motor for 67
Hey guys!! I haven't been on in a while, been busy with other things.
So the 67 is going on the front burner, kind of. We have a 65 C60 with a 327 in it, and that's about the only good thing about that truck. I want to rebuild that motor and put it in the 67 C20. I would like to get 275-300 HP out of it. I would probably have the machine shop assemble the short block, as I have very little experience, and would rather have them deal with making sure the tolerances and everything is correct. What parts (heads, cam, intake, etc.) would you recommend? I'd like to keep it under $2500-3000, as well. Will Vortec heads fit? Also, was a 4 bolt main engine offered in heavy trucks, or were they all 2 bolt mains?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 01-06-2010, 11:04 PM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: Motor for 67
om the performance parts thats up to you, you can easily pull 275-300 hp out of a 327.
just depends on what you are looking for, more top end or low end, what trans do you want to run ect.....
and the best way to find out if its a 2 or 4 bolt main is to pull the pan or run the serial.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 01-06-2010, 11:10 PM   #3
bhoeger70
bhoeger70's Avatar
Re: Motor for 67
vortec heads will make it easy to get 300hp out of the 327. I dont belive the small jurnal blocks ever came with four bolt mains. At 300hp it wont matter two bolts will be more than fine.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 01-06-2010, 11:19 PM   #4
ed2552
ed2552's Avatar
Re: Motor for 67
Ok.
It's a stock 4 speed trans. I'll put in a new clutch at the same time.
Old 01-07-2010, 03:51 PM   #5
ed2552
ed2552's Avatar
Re: Motor for 67
What should I look at for a cam? It'll be a cruiser, that might tow a small trailer around once in a while. Most it might see is a car, but I doubt it. Also, what kind of pistons should i use, assuming it has to be bored .030?
Old 01-07-2010, 05:08 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Motor for 67
With a goal of 300hp tops, I would just use a good set of cast pistons and a nice set of rings, if you want to spend a little more, get hypereutectics, but I don't think they're needed for such a mild build. I'll probably get flamed for saying that, but 300hp is a very mild 327 and if it's tuned well, you should'nt have to worry about detonation if the compression is right (9:1 max at that power level), especially since it doesn't sound like you'll be revving it really hard. I would go for a cam with an advertised duration in the 260* range. that will give you good idle, torque and vacuum. You could easily have an 87 octane motor and your 275-300hp!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-07-2010, 05:38 PM   #7
mrh33916
Project '67 454
mrh33916's Avatar
Re: Motor for 67
Unless you just want to build a 327 for the money you are willing to spend you could get a complete 350 crate motor that makes atleast that much hp.
mrh33916 is offline   Reply With Quote
Old 01-07-2010, 05:55 PM   #8
ed2552
ed2552's Avatar
Re: Motor for 67
A: We have the 327 sitting around, and it needs a home.
B: Everyone and their brother has a 350 crate motor in their car/truck.
C: 327 could have been original in that truck, and I'm going for a vintage type look for it, make it into a 70's dragster tow-truck.
Old 01-07-2010, 05:57 PM   #9
ed2552
ed2552's Avatar
Re: Motor for 67
Well, my goal isn't a maximum of 300 HP. If I could make more, that'd be great, but I don't want 500, either. 300 is a good round number that is achievable with decently priced parts, and shouldn't blow the trans or rear-end.
Old 01-07-2010, 06:07 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Motor for 67
that's why I suggested a nice set of cast pistons and flat tappet cam. I was just saying, if 300hp is your goal (you said 275-300hp), you can do that without dumping a bump of unnecessary high dollar parts into the build. Of course you can always make more, just depends on what you want to spend.
Adam
Old 01-07-2010, 06:24 PM   #11
tonypaul
tonypaul's Avatar
Re: Motor for 67
just another two cents worth- I have done a couple 327s in the past and they are fine motors. But- they are high reving motors that dont produce alot of torque due to their short stroke. If you ever plan to tow something or just want to have some low end grunt, I wouldnt recommend a 327. Once again they are great engines, just takes alot of spinning of the engine to get power out of them.
When it all comes down to it all your gaining on your rebuild is the block and maybe the crank, everything else is going to get replaced. I would take off all the brackets, starter,ect have the heads checked for crackes ect and how big the combustion chambers are. Then look on craigslist for 350 block or shortblock. I see complete 350's all the time around $300.00 or less on craigslist.. Then sell your block on craigslist for the same or a little more. If you have a small journal crank/block they just not as strong as a normal 350.
What I trying to say is your not saving alot of cash for the engine you have and may not be worth the savings just to have something different than the next guy. But what ever you choose I do wish you the best on your project.....
tonypaul is offline   Reply With Quote
Old 01-09-2010, 10:57 PM   #12
ed2552
ed2552's Avatar
Re: Motor for 67
Bump
Old 01-10-2010, 08:06 AM   #13
jim zag
ENGINE BUILDER
jim zag's Avatar
Re: Motor for 67
If you are going to run stock manifolds I would suggest a 268 Comp High Energy. Headers I would say a 270 Magnum. Anything bigger and you may not be happy with driveability.
JIM ZAG
jim zag is offline   Reply With Quote
Old 01-10-2010, 09:18 AM   #14
cdowns
cdowns's Avatar
Re: Motor for 67
crate is the cheap way to do it// a 290hp 350ci runs about 2500-2700 all brand new stuff no waiting plug an play
Old 01-10-2010, 11:20 AM   #15
bhoeger70
bhoeger70's Avatar
Re: Motor for 67
Build the 327 it will work fine in a c20 as long as you dont plan on pulling a 10,000lbs trailer over the mountains. With the stock gears in a c20 it will be geared plenty low enough for the 327 to pull most anything you would want to. Have fun with it and enjoy one of the best sbc ever made.
Old 01-10-2010, 01:14 PM   #16
68Lowrider
Re: Motor for 67
Actually I just had a 327 built and dynoed at Joey Grose Racing in Lodi ca for my 32 roadster pickup .Its a large journal 2 bolt,balanced rotating assembly with 194 fuelie heads ,9 to 1 cast Speed Pro pistons and moly rings, Edelbrock performer cam ,Stainless roller rockers ,Edelbrock performer rpm air gap intake and Edelbrock 500 cfm manual choke carb, MSD ready to run dist it made 301 hp and 360 foot pounds of tourque ,,,,,,
68Lowrider is offline   Reply With Quote
