Old 01-06-2010, 10:24 PM   #1
Cumminpwr11
Southern Nevada Coal Roller
Adding ABS
I want to add ABS to my 72 suburban. I know its expensive but I want it. Any ideas on where to start. I am buying new axles with from Dyna track with ABS stuff built in, just curious about what else in needed. Computer? ABS calipers? anything else?
Thanks Chris
Cumminpwr11 is offline   Reply With Quote
Old 01-07-2010, 05:41 AM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Adding ABS
Modulators.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 01-07-2010, 05:12 PM   #3
woodwright
Enjoying left field
woodwright's Avatar
Re: Adding ABS
I've had ABS on 4 or 5 rigs. Never have liked it much. IMHO, If you know your truck, and how it handles, you could stop just as fast.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 01-07-2010, 06:02 PM   #4
cdowns
cdowns's Avatar
Re: Adding ABS
maybe buy a newer lower mileage tahoe blazer or sub from llike 2005-2007 and transfer the old body to it that way you've cot all the computersa and gizmos you need so it will drive itself
Old 01-07-2010, 07:27 PM   #5
68 short step
Re: Adding ABS
ill give you the basic things that you'll need to know/get....each wheel has a vehicle speed sensor, usually the rotor has the abs reluctor wheel built into it, and the spindle has the mounting positioned just right so the VSS is the proper distance from the reluctor wheel...then the VSS sends that info usually to the BCM, the BCM controls the ABS modulator (thing that all the brake lines go to)....thats the basics, also you'll want the pump motor for the module... the cost involved, would be alot, to retro-fit evetrything... and the wireing would be something to consider too.
cool idea tho
68 short step is offline   Reply With Quote
Old 01-07-2010, 07:27 PM   #6
Ackattack
Ackattack's Avatar
Re: Adding ABS
that's what I'd do too
Ackattack is offline   Reply With Quote
Old 01-07-2010, 09:00 PM   #7
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: Adding ABS
isnt sumbody on here doing just that ?? thinkin its on the burb forum
here it ishttp://67-72chevytrucks.com/vboard/s...d.php?t=348244
tnblazerk5 is offline   Reply With Quote
Old 01-07-2010, 10:50 PM   #8
Re: Adding ABS
Aren`t antilocks just an idiot-proof device?They`ve never made any difference in my stopping ability.It`s for people who freak out when their wheels lock up.Just lift your foot.People still wreck with anti-locks and people still avoid accidents w/o them.If you want then,that`s cool.It`s your truck.
Old 01-08-2010, 09:17 AM   #9
Cumminpwr11
Re: Adding ABS
Thats a good idea about using a chassis with ABS already on. I just need to find a newer dodge 3500 and pull the body off and start again. maybe I can find a good deal on a newer common rail cummins! Nice
I was never a fan of ABS until this winter when the wife and I were in the mountains looking for a Christmas tree in my father-inlaw's avalanche. Driving home a tree flow out of a truck in front of me and being able to steer and brake of snow and ice impressed me enough to want it on my Burb. My burb would have just hit the tree.
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
