Projects follow me home...
![]() Join Date: Aug 2005
I have been trying to search for an answer to this question, but have not come up with anything specific...
The '79 G30 has the 8-lug rims with 800R16.5 tires (aka 8R16.5 / 8.00R16.5) with dual rear (duallies). The multi-part question is: Which Chevy rims interchange with the Chevy 8-lug (& did the Chevy 8-lug rims change after a certain year point)? What year range of Ford or Dodge possibly bolt up? And what tires combine with the rim to are the best interchange, avoiding the possibility of the duallies rubbing? ---------------------------------------------------------------------- Bits of info that I have found: (?) The Chevy rims have small center hub openings when compared to other manufacturers (?) Ford center hub openings are larger, but at some point recently the 8-lug rims for Ford changed. Not sure if that means the later or the recent style is a possible choice. I can not find any specifications/measurements for the different 8-lug rims to compare... I would greatly appreciate any help on this! ~ Steven
'51 Willys Wagon (SBC 350) '56 Willys Wagon (SBC 350) '77 Chevy Corvette 350 '79 Chevy G30 (Coachmen) 350 '79 Chevy G30 (Transvan) 350 |
thinair
![]() Join Date: Jun 2004
Re: Which 16" rims (& tires) interchange with the 16.5" rims?
chevy wheels did not change,all are 8x6.5 bolt pattern
ford wheels changed to a 8x170mm bolt pattern in 1999 dodge wheels are still 8x6.5 your 8.00x16.5s new measure 28.3"......225/70/16 are the same height but you'll have trouble finding a 8 or 10 ply for your dually......... you can use 215/85/16,225/75/16,235/85/16,and 255/85/16 without any tires rubbung in the rear and get your heavier plys hope this helps you |
Excellent info! Thank you thinair!
![]() So, the Ford 1998-older rims are 8x6.5 also? Can you confirm the info about Ford centers being larger and fitting Chevys? Essentially, that would mean that Ford (pre-1999) rims fit Chevy, but not the reverse (Chevy rims ->Ford). What about Dodge rim centers? ~ Steven
#4 | |
#5 | |
6.0 powered square
yes there's several members with 73-87 with 99 and up 8 lug wheels
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#7 | |
Hopefully we can get some examples of some swaps others have done between years and possibly different makes.
6.0 powered square
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 01-07-2010 at 11:24 PM. |
Those rims look really sharp.
The other thing those alloys have going for them , other than they are about half the weight of a steel wheel, is they are about twice or three times the load rating of a same size steel wheel. They also give you better handling, stopping, and acceleration because of their weight. I had a set of 3/4ton running gear on my 1974 Ramcharger, and with the steel wheels and 38in SuperSwampers, it got 9mpg, when I switched to same size alloys, my mileage went to 11, and the accelleration and braking improved noticeably. Same thing happened on my 1993 F150 4x4 when I went from the 15x10 steels to a set of 15x10 alloys.
#12 | |
Does anyone make 8x6.5 dully alloy wheels?
#13 |
#14 |
