01-07-2010, 03:36 PM | #1 |
AIRBAGPARTS.COM
Getting a 1 ton on the ground *questions*
A buddy just got an 85 Chevy crew cab dually. He wants to get this on the ground. I have done many 1/2 ton truck but I am not very familiar with these 1 ton frames. My question(s) is, what do I need to do to get this to lay body? How big of a "Z" would I need and would I be able to just hack off the bottom of the frame?
Thanks guys and any help would be great... |
01-07-2010, 08:07 PM | #2 |
67-72 parts collector,…
Re: Getting a 1 ton on the ground *questions*
Have you thought about a Dropmember?
Nate's also got those sweet tubular a-arms,... and he makes them to fit the 3/4 ton and 1-ton trucks. Sorry I didn't really answer your "Z" question. I just think it's easier than cutting the frame up. Maybe someone else will chime in. Last edited by lolife99; 01-07-2010 at 08:09 PM. |
01-07-2010, 09:55 PM | #3 |
I'm lazy i rather buy a dropmember then z a frame.
01-08-2010, 12:03 AM | #4 |
3DrDwn--the 'burb not the band
on the 1ton Squares most get lucky and do not need the raised crossmember. Unlike the lighter trucks the skid plate on the suspension cross member is usually higher than the bottom of the frame making the rails the first thing to touch ground.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
01-08-2010, 01:59 AM | #5 |
It'd be alot cooler if you did
any body have pictures?
01-08-2010, 11:25 AM | #6 |
AIRBAGPARTS.COM
I am trying to convince him to get the dropmember, but he is really trying to save some money and he has the tools and ability to do the fab work. I was just trying to get some sort of starting point for him.
*on a side note: I bought my rack and pinion on Tuesday, so my dropmember will be going in pretty soon. YAY ME...* |
01-08-2010, 11:43 AM | #7 |
z ing the frame will not let you lay body the frame is 4 inches lower than the rockers, a stock floor body drop using a 2x4 .250 wall will get you what you want also what kind of wheel tire combo are you planing on running 19,22,24, you can use single wheel front and rear parts to narrow the track or c&c rear if you want to get real narrow in the rear. this is what i'm doing on my 84 1ton dually crew cab. as far as a pb dropmember goes nate said as long as you are running a small block the rack would be ok. hope this helps any other questions let me know. later paul
01-08-2010, 08:46 PM | #8 | |
some of my current one can be found here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Josh
