01-07-2010, 04:02 PM | #1 |
clunk when turning
Anybody else ever fought a clunk while turning on these trucks(4wd)? I get one single clunk which sounds like its under the drivers floorboard when i turn and it doesnt always do it. Does it turning both ways.
This is the truck in my signature
1972 C10 cheyenne super -350/th350 Wifes truck 1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc 2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear. 2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies. |
01-07-2010, 04:18 PM | #2 |
Re: clunk when turning
i had a similar problem, it was the pitman arm, it was way worn out, might be something to look into
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
01-07-2010, 04:58 PM | #3 |
i would check all your ball joints, if they are worn or lose they could be making the noise.
1963 CHEVY C-20 292/4-speed-Hydraulic dump bed 1974 GMC C-25 454/400 Camper Special 1977 CHEVY K-10 350/350/203 shortbed 1979 GMC C-15 250/465 short bed, stepside 1980 CHEVY K-20 350/465/205 1980 CHEVY K-20 (Built)427/400/205 1981 GMC K-15 350/465/208(Retired) 1983 GMC K-35 454/465/205 winch truck 1985 CHEVY C-30 454(18,000 m.)/465/PTO |
01-07-2010, 08:46 PM | #4 | |
I will check the balljoints also. Thanks guys
01-08-2010, 11:04 AM | #5 | |
It could also be the axle joints. Though it can be hard to tell while the front end is assembled.
Jack the truck up to get one front wheel off of the ground, lock the hub. Then turn the steering wheel so that the tires are not pointed straight foreward. At that point, spin the raised tire by hand. If the axle joint is starting to get stiff, you can "feel" it. The wheel may be very hard to turn in some places or even try to straighten out. If everything seems ok, un-lock that hub and test the other side. As these joints stiffen up over the years they start tearing up the inner bearing and the guts of your lock-out hubs as well as the end of the spindle. It's a good thing to check/inspect regularly.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-09-2010, 11:44 PM | #6 |
haha, ford guys...
check your wheel bearings and upper and lower shock mounts.
01-09-2010, 11:55 PM | #7 |
I checked my lifted steering arm with my 4 foot long 1/2 rathchet and cranked each one of the nuts down probably atleast 1 turn, then went and drove it. It only started to clunk after like 15 miles and it only did it twice so that may be my problem but i will check the others you guys mentioned.
01-10-2010, 12:02 AM | #8 |
haha, ford guys...
sometimes when the upper shock mounts are lose for so long they will be eaten by the frame, thus when you tighten them they do nothing, this could be your problem, but with 4x4 there could be many more things that have done wrong.... its very possible that a ball joint has been knotched by some one 4x4'n the hell out of it and or not lube-ing the joints. its hard to say unless you do a tear down...
if you jack up the front of the truck by the axle or cross member you should be able to move the wheels with your hands... turn them from max to max and listen and feel for anything abnormal (turn the wheels by grabbing the wheel and musceling them around... not by using the steering wheel) |
01-10-2010, 08:51 PM | #9 |
Well ive 4 wheeled the hell out of it
Havent had a chance to really look at it yet, Hopefully sometime during the week. Thanks alot guys!
