01-07-2010, 04:56 PM | #1 |
Free Saddle Tanks
Removed from 71 C-10. Good condition.
You must pick up in Southern California. |
01-07-2010, 05:53 PM | #2 |
Moderator
Re: Free Saddle Tanks
Where were you 6 months ago?! Do you have any other parts?
Bump for you.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 01-07-2010 at 05:54 PM. |
01-07-2010, 06:02 PM | #3 |
Thanks for your generosity to the Board. I may be able to take them but need to know if they also would fit a C 20 (bigger frame) - does anyone know about this.
Could you be a bit more specific about your general SoCal location in case I might be able to have somone come get them? Thanks, CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
01-07-2010, 06:07 PM | #4 | |
Not sure for C-20 (Probably) I'm in Lancaster, Los Angeles County.
01-07-2010, 06:29 PM | #5 |
Moderator
I have a set that came from a C-10. They fit fine in my C-20. I do not think the C-20 frame is any "bigger" than a C-10 frame. I have read that they are identical, with the exception of a few different crossmembers. Someone else will chime in to confirm or deny this I am sure.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-08-2010, 03:23 PM | #6 |
Are these the tanks that have the fuel filler in the wheel well?
01-08-2010, 06:35 PM | #7 |
01-11-2010, 10:54 PM | #8 |
Thanks DT1, am very interested. Need to find a way to have someone pick them up. Working on it. CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp Last edited by CCCC; 01-11-2010 at 10:55 PM. |
