01-07-2010, 08:48 PM | #1 |
8 lug to 5 lug???
Can anyone tell me what exactly i would need to do that swap? will 5 lug spindles fit 3/4 ball joints or any info would be really helpful because i love torque thrust rims and i really want to be able to put them on my pig:]
01-07-2010, 08:51 PM | #2 |
Re: 8 lug to 5 lug???
too bad you are not in FL we could swap frames!
01-14-2010, 01:46 AM | #3 |
im doing this same change from 8 to 5 do you plan on lowering it i got a rear end out of a 75 c10 donor truck and drop spindles for the same and ball joints went right together
01-14-2010, 02:48 AM | #4 |
I did it to my 72 C-20 burb. let me see if I can dig up some pics
01-14-2010, 03:06 AM | #5 |
the rear end was a straight swap, had to have a custom u-joint installed to match the 3/4 ton driveshaft to the half ton axle
For the front, you need to change the upper and lower ball joints, use a half ton spindle, half ton bearings, rotors, and tie rods. The calipers are the same. |
01-14-2010, 07:02 AM | #6 |
ENGINE BUILDER
I am not sure but looking at my 68 C 20 lower a frames I think the lower ball joints might be a larger outside diameter. I think the lower a frames might be different. The size of the hole might be larger. Anyone know for sure?
JIM ZAG |
01-14-2010, 11:29 AM | #7 |
Yes the lca carries a different ball joint. It is a larger dia. than the half ton. I found some threads about changing to a six lug front disk brakes using a 68 3/4 ton lower contol arm and using spindles and rotors from a c-1500 88-98. The top ball joint was changed to the later ones as was the bottoms and they fit perfect. So, if that was done to change to a six hole disc it could be done to change to a 5 hole just as easy because the 1/2 and light duty 3/4 from that time carry the same spindles and bearings. Jim
