Old 01-07-2010, 10:28 PM   #1
67chevy2wd
67chevy2wd's Avatar
Built a cab dolly today.
I built a cab dolly for my cab today. I used the casters I did because it was all the local hardware store had. I need to get some bigger ones and change it to 4 I think. Otherwise it is pretty sturdy. I plan to use it on the next cab I rebuild rather than doing it on the frame. The floor of the cab is about 2 1/2 ft off the ground. I built it to use just the rear cab mounts so the front board won't be in my way for the next cab when I replace the floor support.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 01-07-2010, 10:33 PM   #2
msgross
msgross's Avatar
Re: Built a cab dolly today.
I would add a few diagonal pieces so it won't fold up on you... Harbor freight has some cheap casters... similar to mine but a little taller.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-07-2010, 10:37 PM   #3
67chevy2wd
67chevy2wd's Avatar
I plan to but I ran out of wood. I built this with wood I had saved from with I tore a wall out of my garage. I will buy some good casters the next time I go to Bismarck. (the closest "city" with real stores) I live in a town of 1000 people so our hardware store doesn't carry everything. I forgot to mention it is screwed together with some heavy screws.
'71 GMC 3/4 ton 4x4
Old 01-07-2010, 10:40 PM   #4
msgross
msgross's Avatar
I would hate to be leaning on it when 400lbs decides to shift... makes it easy to move around the garage though doesn't it?
The Garage:
Old 01-07-2010, 10:46 PM   #5
67chevy2wd
67chevy2wd's Avatar
Yes it is real easy to move it now. I am going to buy some wood tomorrow to put more braces in. As the cab sits now the dolly is plenty strong but if I hang doors and other stuff I think it might be a little weak.
'71 GMC 3/4 ton 4x4
Old 01-08-2010, 10:15 PM   #6
67chevy2wd
67chevy2wd's Avatar
added some braces today. Gonna pic up some new casters on sunday.
'71 GMC 3/4 ton 4x4
