Old 01-08-2010, 12:21 AM   #1
xxjr89xx
c10 spindles on c20
i have a 1984 c20 that i want to convert to either a 5 or 6 lug...how would i go about doing this? can i just buy c10 spindles and mount the c10 brake setup?
xxjr89xx is offline   Reply With Quote
Old 01-08-2010, 12:25 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: c10 spindles on c20
The c10 parts won't work on your c20 spindles.
But ECE, (www.earlyclassic.com) sells a "conversion spindle" that will allow the C10 parts to bolt on while retaining your stock c20 ball joints and tie rod ends.
Give Stan at ECE a call and tell him you heard about it here on this message board.
Old 01-08-2010, 12:27 AM   #3
xxjr89xx
will do, thanks for the help!
Edit: new problem...checked their site...know of any place that sells 5 or 6 lug converted axles?
Old 01-08-2010, 12:38 AM   #4
lolife99
lolife99's Avatar
I think a complete rearend swap would be your best bet.
I think you should be able to find one for around $100.
Just remember you need to be a subscribing member to post WTB ads here.
Good luck with your project,... and post up some pics when you get time.
Old 01-08-2010, 12:42 AM   #5
xxjr89xx
In the long run, might be worth the subscription as for pics...i'll be getting some soon... going to be a long project. Low income + bills = long project
Old 01-08-2010, 02:00 AM   #6
joe231
joe231's Avatar
If you want 6 lug, on the front you can use early 90's light duty 3/4 ton spindles, rotors, and calipers, but you will have to change ball joints also.
CHEVY ONLY
