Old 01-08-2010, 02:17 AM   #1
csa daddy
csa daddy's Avatar
one wire alternator
ok this is a litte bit away from trucks but i know a 68 truck is pretty close as far as wireing goes to a 68 camaro. this is the ? after you hook up the postive wire from the battery to alt how does the vehicle body receave power
csa daddy is offline   Reply With Quote
Old 01-08-2010, 06:22 AM   #2
bsm78
Re: one wire alternator
i checked on one of these at the local napa for my c10. from what im told you just run your positive to the battery and thats it. the alt gets what power it needs from the bat and detects when it gets low and recharges it. the battery will still be grounded to something on the truck which will also be connected to the alt.
bsm78 is offline   Reply With Quote
Old 01-08-2010, 07:14 AM   #3
jim zag
ENGINE BUILDER
jim zag's Avatar
I have one for running engines on my engine test stand and all you need to do is run the battery wire to the output terminal and it works.
JIM ZAG
jim zag is offline   Reply With Quote
Old 01-08-2010, 07:30 AM   #4
Rich48
I have been using one of these one wire alternator no problem, but am also using a voltmeter gauge in my dash so i can see that battery is charging as you will no longer be able to have the warning light on the dash working
Rich48 is offline   Reply With Quote
Old 01-08-2010, 12:57 PM   #5
71tahoe
71tahoe's Avatar
On a chevy truck the power for all your accessories doesn't go through the alternator. There is a terminal on the fender that feeds the wiring harness.
I have no idea on a camaro.
71tahoe is offline   Reply With Quote
Old 01-08-2010, 01:16 PM   #6
fixit-p
fixit-p's Avatar
On Chevy trucks the alt buss connection is a soldered splice on the left fender well the buss distributes power from the alt to the batt and cab. On cars (Camaro included) GM used the horn relay as the buss to feed batt and cab. IMO one wire alts belong on lawn mowers and forklifts or anywhere else that you just want to charge the batteries.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
