01-08-2010, 03:25 AM | #1 |
Lowering help?
Ok, i'll make this quick. As i've said before i am very new to trucks. I'm just curious how i go about lowering my 68 longbed. It still has drums all around. And i'm looking for a cheap way, not bags at this time.
1968 GMC LWB (327 DD SOON!) 1990 Honda Civic (DD for the moment) 1999 BMW 323i (Full M3 Conversion)R.I.P 1992 Nissan Sentra SE-R (SOLD) 1993 Honda Del Sol H23/22 (SOLD) 1993 Toyota MR2 Turbo (SOLD) 1993 Honda Civic(First Car/SOLD) |
01-08-2010, 04:07 AM | #2 | |
'69 Chevy SWB
Re: Lowering help?
Early Classic Enterprises has a pretty good selection of lowering springs and front disk brake conversion at a pretty reasonable price. you might try their web site and see what you can find that would work best for your needs.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
01-08-2010, 07:35 AM | #3 |
Re: Lowering help?
I believe you can change out the spindles for something later with disc.Look at lmctruck.com they sell just about anything you could want.Look at the 67-72 part of this forum you mind find your answers in there.
01-08-2010, 09:24 AM | #4 |
67-72 parts collector,…
Re: Lowering help?
01-08-2010, 03:15 PM | #5 |
Grandpa in the rustmobile...
Re: Lowering help?
id go conversion drop spindles in the front with 6 lug rotors new bearings seals and then a 4 5 6 inch drop spring..
TORCH EM...hahA
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-08-2010, 03:20 PM | #6 |
Re: Lowering help?
pull out the front coils and cut one round off for 2 1/2" - 3" of drop
install late 60's chevelle/malibu spings and a 1 1/2" lowering blocksin the rear. cheap. easy. fairly low. |
01-08-2010, 09:39 PM | #7 |
Re: Lowering help?
Thank you all a ton, i appreciate all the Input you guys have. I'll definitely have to check out those sites, and think about cutting the springs. How do cut springs effect the ride? And how dangerous can those babies be???
01-08-2010, 10:35 PM | #8 |
Chevy Lover Till The End.
Re: Lowering help?
Hello, I think this is a pretty good kit and fairly inexpensive.www.brotherstruckparts.com part # LSS6372-8
01-08-2010, 10:39 PM | #9 |
Nothing to see here.....
Re: Lowering help?
cutting the springs isn't dangerous, it's the removing part that could hurt........
cutting the springs has been around since the 50's, and it's no big deal. HOWEVER, cut only a little at a time and cut less than you think you'll need. the stock springs are and can be a bit weak at this point...... so cut sparingly at first. like Shane said above, hit a salvage yard for rear springs. they cannot be cut down so you must change them out. iirc, you can also use mid to late 80's Taurus/Sable springs to drop the rear a bit. but DO NOT heat the rears to get your drop. you'll lose your ride and it can weaken the spring. there you go, drop on the cheap.....
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
01-09-2010, 12:43 AM | #10 |
Re: Lowering help?
I'll have to check that part out camaro_nut! And thanks for the info TCB, i'll attempt my first spring cut! This should be interesting haha. Thank you guys for the info!
01-09-2010, 12:25 PM | #11 |
Re: Lowering help?
I suggest buy a set of drop rear springs for your truck.
Then cut the front springs for "cash friendly" drop. Just make sure you cut the bottom of the spring,... not the top. I use the formula: 1/2 coil cut = 1" of suspension drop. Get it where you want it,... then head to the alignment shop, or you'll be wearing out those front tires quicker than you want. Then when you get a few more dollars,... invest in some drop shocks and a sway bar up front for better handling. While you have everything apart, look at the condition of the ball joints and tie rod ends. Brake hoses are another good thing to inspect. It's a perfect time to make sure your truck is safe. Not just cut and drop. Last edited by lolife99; 01-09-2010 at 12:28 PM. |
01-09-2010, 12:35 PM | #12 |
Re: Lowering help?
^^^^ I would go this route if your on a budget
Adam M STX Designs Motorcycles | Choppers | Hotrods |
01-09-2010, 12:41 PM | #13 |
Happy to be here
Re: Lowering help?
Just remember, cut springs are good, heated springs are bad....very, very bad.
01-09-2010, 02:13 PM | #14 |
Re: Lowering help?
Well lolife, i think i'll be following your instructions haha. sounds like a good plan to be honest. Thanks for the info!
10-13-2014, 04:05 PM | #15 |
Re: Lowering help?
a lot of good info here but I have a question also, if I cut one coil of the front springs. now I want to buy rear springs, what drop should I get? 4" or 5"? thanks
