The best crate motor for the job
I am asking everyone's opinion on what the best crate motor for my truck would be. I have been bouncing between an EFI 572, or the 502 ram jet. My goal is to build the ultimate work truck. It will have to be a daily driver. I have 2 front dana 60 axles that after rebuilding will be going on the truck. The frame will be boxed by the time the motor is purchased. I plan on installing the biggest alternator I can find (amps not girth). I would like it to be fuel injected and gas powered. As soon as I find a 700r4 to rebuild to handle the power that is my tranny of choice, but open to suggestion. The truck will remain looking mostly stock. I will be getting a fisher V-plow to replace the old set up.
Re: The best crate motor for the job
if your just going to use it as a work truck, and plow with it, why not just buy a gm performance parts 454 w/4l80e trans? save your money, that efi 572 aint cheap
1987 350 TBI lowered 5/7 |
I think in the summer time I would like to go to some of the truck pulls. That and I just wanna go big, you know.
Master Hater
build your own, Its cheaper And it won't be made in Mexico.
It'd be alot cooler if you did
even still, have you seen the price tag on a 572? You could build a 454, and have enough money left over to buy a whole pulling truck.
The 572 I am looking at costs 16,000. The 502 Ram Jet costs 11,000. I have a budget of 30,000 to work with. I know I could go out and a brand new truck but if everyone did that forums like this would loose there place. I am going to wait until next year to start most of the work. I will have more money saved up by then to do the other stuff. I will take a look at the 454 but I really want something with 450 to 500 hp.
BAD BOW-Silverado XST
You can install a stock 145 amp alternator. I have one on my truck from a 08 truck.
Wow, daily driver with a BB. HMMMM, take a look at the RAM Jet 350. Power and FI dependability. You can build a 383 and add FI. Ram Jet FI works great with a 383. Really consider fuel costs of a daily driver. Don't discount diesel either!! |
A 30K budget? Do a 540 w/a turbo if you must have a big block. Much more power than a 572.
The One And Only !!!
With a 5 spd and about 475 ponies mine only gets 13 mpg mixed, Just not good enough for me to drive daily.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Honestly a Duramax/Allison would do the job much better and get you further down the road for your money. Turbo diesels maintain mileage while pulling, gas engines lose mileage exponentially as you add weight.
Not only that, you just aren't going to get that much life out of a gas engine running it hard all the time. Diesels are designed to be run hard all the time. If you just have to have a gas engine, try a Vortec 8100. 496 cubic inches and with a cam swap and tune it'll put out massive torque numbers. You can get a low mileage motor for little money. For this power level, you can forget about a 700R4. Even if you spent a ton of money on it, it just wont last at this power and weight level.
1977 GMC Sierra Grande Last edited by Pyrotechnic; 01-08-2010 at 01:07 PM. |
I would go with a duramax allison combo but I have heard it is very complicated, and hard to find. The newer efi crate motors are an easy install. I am getting between 10 to 12 mpg right now and 6 to 8 with the plow on and ballast in the back. It will probable get worst when I install the dana 60's because they are 4:56 and the ones I have now are 4:10 I have also got to find a transfer case with a PTO provision. I think I need to slow down and tackle one project at a time. I just like to have a plan so I can make it easier in the future.
#12 | |
67 chevy c 10 2x4 350/700r4 short/fleet 90 Chevy 1500 4x4 350/5 spd short/fleet 90 Chevy 454 ss 93 chevy camaro z28 auto t-tops 2013 Chevy Silverado LT CCSB 4x4 |
#13 | |
#14 |
Yes you read right but that was a lot of ramen noodle dinner, 12 hour work day, not going to the bar, snow plowing, penny pinching, and not spending foolishly. So I can spend foolishly on my truck. I am not a rich kid, I wasn't born with a silver spoon up my but, and there is no trust fund with my name on it.
#15 | |
Still plays with trucks
http://www.jegs.com/i/World-Products...oductId=758097 Spend the $5000 you save over the 572 crate motor and put it elsewhere in the truck.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#16 |
On a budget like Fred Sanford
$30k? With a budget like that, if you wanna get stupid with the motor (I saw "ultimate truck" in there somewhere) then forget about crate motors.....step up to the plate and do a big boy dart block and build a 632".
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
#17 |
With the budget you've got, why not build a pulling truck and buy some POS for a daily driver & plow truck? It seems foolish to piss that kind of money into a daily driver that's going to get wasted by all that road salt.
#18 |
What about a 454 lsx?
#19 |
motor exploder
I was thinking that same exact thing when I read the OP. You could get two reasonably sized turbos that would spool quick and have a beasty motor from idle to redline. You could throw down 800 or 900 lb-ft all day long.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#20 |
WOWeee!!!!
...and I thought my GM 350 stock crate engine was the Cat's Meow!!!
#21 |
How about an LS7?
http://www.sdpc2000.com/details/gm-p...parts/17802397 Less money than the 572 and way cooler. Can you say titanium connecting rods? Or an LS3 with a pair of turbos would cost even less and build more power. http://www.sdpc2000.com/catalog/ls-g...-crate-engines
#22 |
Cummins 6BT with a NV5600. Not complicated, there not computer controlled,
easier to work on than a duramax. For a plow truck with todays fuel prices diesel is the way to go. |
#23 |
are you kidding me 30 grand? i would no doubt in my mind throw a cummins 6bt and a nv4500 or 5600 in my truck and get 20mpg with 700hp...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#24 |
#25 |
your right maybe not 20 but get better gas mileage than a big block.
