01-08-2010, 10:19 AM | #1 |
5 on 5" BC slip-on style rotors?
Are there any of the later model 1/2 ton trucks that had the top hat style slip on rotors with a 5 on 5" bolt cirlce? Looking for cheap factory style rotors I can use on a home built rear disc set-up. So what year truck should I be looking at to find such a thing?
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
01-08-2010, 10:53 AM | #2 |
Re: 5 on 5" BC slip-on style rotors?
I'm using 77-78 Cad Eldorado rear rotors you will need to machine part of the axel flange face but theyre the right thickness and 5 on 5 bolt pattern
01-08-2010, 09:04 PM | #3 |
Happy to be here
I'm pretty sure that all the later trucks with two piece rotors are 6 lug.
01-09-2010, 02:45 AM | #4 |
impala maybe?
01-09-2010, 12:29 PM | #5 |
For the rear try 91-96 Caprice or 94-96 Impala oh and I think 93-96 Caddy Fleetwoods
Adam M STX Designs Motorcycles | Choppers | Hotrods Last edited by ShowSS12; 01-09-2010 at 12:31 PM. |
01-09-2010, 06:15 PM | #6 |
Do a search for Impala Caliper Bracket. The mid 90's Impala SS rotors are 5 on 5. Tons of info on this here. What calipers are you planning to use?
01-13-2010, 02:29 AM | #7 |
60-66 Nut
If you want to use the typical 'old style' GM calipers, you can use '77-'79 Lincoln MKIV rear rotors. If you would like to use the newer style calipers as in the '94-'96 Impala's and Caprices as well as the '94-'97 (?) Camaro's (integrated parking brake) then use the Impala/Caprice rotors. If you decide to go with the Lincoln rotors, you will need to machine the OD of the axle flange to fit inside the rotor.
