01-08-2010, 03:53 PM | #1 |
putting on new Grant Steering Wheel
I am putting new steering wheel and they have confused me. The old horn assembly with the brass that is spring loaded I am wondering if I am to pull the brass out of my old hub or to leave it in and let the new one take its place.
Has anyone done this and can you help me. It is a Grant steering Wheel and grant installation kit.
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe. John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me. My Book "Why Cancer is Not Bad Luck" by WestBow press |
01-08-2010, 03:58 PM | #2 |
Re: putting on new Grant Steering Wheel
bout to do the same thing tomorrow. ill let you know what i run into also
01-08-2010, 04:05 PM | #3 |
me three...
subscribed... |
01-08-2010, 06:57 PM | #4 |
Its a Truck Thing......
yes you have to pull the brass plunger out of the turn signal cam, dont loose the spring, i used it with the new parts, the spring that comes with the kit is too long.
Let me know if you have any trouble, Ill walk you through it. Just put one on my truck, Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
01-08-2010, 08:15 PM | #5 |
I pulled the brass plunger out of the old turn signal cam, but used the new spring. I thought about the old spring, but did not use it.
I may take if off tomorrow and align the steering wheel a little more and use old sping as the longer one is really hard to get in. Looks great and eveything works fins. Thnaks for the help!
01-08-2010, 09:59 PM | #6 |
Any pics ,Im planning the same thing.
06-18-2010, 02:50 AM | #7 |
The Stud in my column that you actually bolt the steering wheel onto is too short with the adapter and everything on it. Once i get everything screwed together I can't get the actual Bolt to catch. What do i do?
'69 Chevy Stepside 350sbc 4speed automatic 2wd ~There is nothing wrong with America that the faith, love of freedom, intelligence and energy of her citizens cannot cure. ~ Dwight D. Eisenhower |
06-18-2010, 03:24 AM | #8 |
Big Red - Now its a SWB!
The directions on how to make the horn button plunger set up are a little hard to understand, but if you play with it you'll figure it out. You have to pull the plunger out, then I put in the new spring, then plunger, then the plastic insert, then use some tape around the plastic insert to hold it all together while you get the wheel on. It took me a few tries and some choice word to get it all buttoned up. After you get the wheel on then you need to put some tape on the horn button spring on top of the big nut so you can pop on the cap. Make sure to disconnect the power before you do all the horn hookup, I just figured it didn't matter much and started hooking it up but let me tell you the nice shiny metal makes for one good connection and it zapped the hell out of me. Good luck and if this makes absolutely no sense let me know and I can get some pictures of mine.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 06-18-2010 at 03:24 AM. |
06-18-2010, 03:41 AM | #9 |
No the directions make sense. i can get everything right up until the part where i bolt everything to the actual column because the stud that holds the steering wheel on is too short for the bolt to actually catch any thread
06-18-2010, 03:54 AM | #10 |
Only thing I can think of trying is put just the aluminum hub piece on then put on the nut and tighten it down. This might pull the hub further in on the spines to get you more shaft to thread onto. then pull the nut off and try to put the wheel on again. Hope it is this easy to fix, good luck.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
