Dually Tires - How Big?
I’m restoring a 1984 K30 one ton (ex-military M1028A3 dually). It had Buckshot 305/70R16s (33s) when I bought it, they look like one huge tire in the back because there’s no gap between them… I know, everyone says bad news… rubbing, heat, blowout, etc. But they must be a pefect fit because after disassembly there’s not so much as a smudge on the sidewalls… and I was goosnecking a 30 ft 5th wheel so they were loaded.
Anyway I’d like to go with bigger tires, probably 35s or 37s. So my question is… what’s the biggest tire size I can run on a dually? I’m guessing the answer is as big as I want, as long as I use a spacer to keep them apart. So assuming I get fender clearance with a lift, then dually tire size would be limited by wheel width… up to 35s on a stock 6-7” rim, 37s (and up) on a 10’ rim… correct? As for width... 12” wide no spacer… 12.5” or wider, need spacer, correct? Thanks! |
#2 | |
Re: Dually Tires - How Big?
You may run into a gear ratio issue with a tire that big, especailly if you do a lot of towing.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
It should have 4.56 gears already...but with tires that size aren't the optimum for towing.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 01-08-2010 at 06:16 PM. |
Dually Pride
i hear 9.00-16 are a good size. I personally have 235/75r16, which are like 32" tall
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
Or if you really want big tires the semi wheels can do it but are pricey.
Rottenwood Garage Member
Agreed.........9.00, 225's, 215-85, 235-85 all wor and look correct
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Check out this badass off-road tow truck it has 37's with tubes on the stock rims with spacers, watch the video at 2:53 the axle hub is flush with the outer wheel flange
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 01-09-2010 at 11:12 PM. |
i run 38.5x11 super swamper boggers accross the back of my crew cab dually with a 2 inch spacer between the stock wheels. no rubbing and looks sick!
the fleet..... 57' shortbed stepside 4x4 72' longbed cheyenne super 4x4 78' blazer lil lift w/ chalet 84' shortbed lowrider aka "troubletruck" 84' 1 ton crew cab dually lifted 8" on 38.5 boggers 87' burb shes my daily 89' blazer, wheelin/plow rig 8?' blazer chassised super short stepside |
