Old 01-08-2010, 07:11 PM   #1
hippycarguy
67 3/4ton p/u low buck lowering
I have a cherry 67 3/4 ton truck that i damn neer stole. problem is i don't want heavy susp. i want to slam to ground with cool wheels without changin axels & spindles. not goin to pull anything & not concerned with weight. can i put 1/2 ton springs instead of 3/4 springs? Any suggestions on spring hieghts? don't want to drag on every bump. also will newer 3/4 alloy wheels fit old axels?
hippycarguy is offline   Reply With Quote
Old 01-08-2010, 08:45 PM   #2
Sublvr72
Sublvr72's Avatar
Re: 67 3/4ton p/u low buck lowering
is it a suburban or pickup? Suburbans have heavy duty coils that you can swap lowering coils in. If it's a pickup it's got leaf springs and you will need to do an axle flip kit or lowering shackles.
1/2 ton swap is easy to do. I did it on my old 72 suburban, hardest part is finding half ton suspension and a half ton axle.
Sublvr72 is offline   Reply With Quote
Old 01-08-2010, 09:35 PM   #3
hippycarguy
it's a pick up & it has coils.
Old 01-09-2010, 02:17 AM   #4
Sublvr72
Sublvr72's Avatar
then same as the suburban, swap in lowering springs.
Old 01-14-2010, 10:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
moved off the suburban forum to the truck forum
Old 01-15-2010, 10:58 AM   #6
hippycarguy
Yes i did, I'm new to forum, didn't realize i was in wrong place. Love the burbs & pnls though! I've seen a 66? short pnl about 25 miles from me, just waitin for someone to make a cool truck out of it. Maybe me!
Old 01-15-2010, 11:23 AM   #7
Ackattack
Ackattack's Avatar
cutting the front coils and 2" drop blocks will get you started for very cheap. If you want to go lower in the back you can add 1/2 ton drop springs or air bags.
In the front there isn't a whole lot of option without changing spindles. I know ECE makes some drop spindles for 3/4tons that will get you down another 2-1/2"
Ackattack is offline   Reply With Quote
Old 01-15-2010, 11:34 AM   #8
Sinister
Between Trucks...
Sinister's Avatar
GMC Paul's has 3/4 ton drop springs.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
