Old 01-08-2010, 09:48 PM   #1
sleepertruck72
sleepertruck72's Avatar
Question Cab swap question
I am looking at cabs to swap the little window out of my 67 stepper. I looked at a pretty nice cab today from a 71 non AC auto with low tunnel. He also has a 69 (he thinks) A/C cab auto low tunnel cab that has more obvious repair needed (rockers, some windshield area rust, drip rail, roof dents) I want to eventually add a vintage air A/C system and I am wondering how much work it is to add the system into the non A/C cabs. I know I can drill the holes for the a/c balls and the one above the radio, but other than that I have no idea what else would be involved. If anyone here has done this swap, please let me know how much trouble it is or if I should just look for an A/C cab. I just hope the cab is as solid as it looks, the last cab I had looked great, and it was a can of worms
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-09-2010, 05:32 AM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Cab swap question
67 has hand type parking brake, 70-72 has foot parking brake. Holes in firewall are different. Also you must consider weather you need a high or low transmission hump.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 01-09-2010, 10:26 PM   #3
sleepertruck72
I like the foot parking brake, and I have a spare set up for that. If I eventually swap to a manual tranny , I guess I would have to cut and make a high hump ? Mainly I want to get the Vintage Air unit for the HOT summers. I think I need to visit the Vintage Air website Thanks for the input
72 C20 Longbed
05 1500 Z71
Old 01-10-2010, 01:59 AM   #4
71 super
71 super's Avatar
You don't have to have the high hump unless you go to a truck type four speed (sm465) if you go with a 3 speed or any of the car four speeds, t10, saginaw or muncie you can use the low hump with no problem. 67-68 had hand type emergency brakes, 69-72 were foot operated types. As far as the a/c this has become a fairly common addition. There is a difference in the heater cut out on the firewall that you will have to change as well as cutting the holes for all of the a/c vents. A easier method if you can find one is a dealer installed a/c unit or vintage or old air products type a/c system this allows you to put vents where you want them i.e. stock or otherwise.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
