Old 01-09-2010, 03:02 AM   #1
NelsonMahrt
NelsonMahrt's Avatar
Updated Heater
Has anyone done a heater upgrade to a 66? I'm thinking of going with a 2000 or newer Chevy heater box/fan unit and controls. I just like the dials or butons. I know that I will have to plug and recut the firewall and the dash cluster will need to be molded in. Any Ideas?
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his truck.
NelsonMahrt is offline   Reply With Quote
Old 01-09-2010, 04:36 AM   #2
LILRED66
LILRED66's Avatar
Re: Updated Heater
What I have discovered with the '60-'66 Chevy/GMC trucks, is a properly maintained and functioning heater/defrost system, is more than adequate to heat/defrost the cab of the truck. Start by replacing the blower motor and squirrel cage, heater resistor/element (in the backside of the underdash plenum box), heater core and gaskets. Also, make sure the gaskets are properly installed and functioning. Also, make sure the door-to-cab seals, vent seals, window run channels & anti-rattle wiskers are in good working order. Properly sealing all firewall openings, as well as, installing a good jute backing and sound-deadener will enhance the heating efficiency of your factory system.
LILRED66 is offline   Reply With Quote
Old 01-10-2010, 04:06 PM   #3
NelsonMahrt
Re: Updated Heater
I can find a ton of motors but can't find a squirrel cage. What years will fit the motor and housing? anyone have a photo of the heater resistor/element so I know what I'm looking for? The cab in this truck had been on fire at one point so I have no wires or heater controlls running to the hearer connections other than a universal heater switch that turns on the fan.
Old 01-10-2010, 04:41 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Updated Heater
Part number HAC-16 on the attached link is a replacement fan for a 1966. Pictures of the resistor are shown next down on the page.
http://www.americanclassic.com/asp/d...to&exyear=1966
Old 01-11-2010, 01:08 PM   #5
NelsonMahrt
Re: Updated Heater
Thanks for the link and information! Maybe I can get some heat in this truck before the temp gets above 30. lol
Old 01-12-2010, 12:36 PM   #6
Vernski
Re: Updated Heater
Nelson here's another link for a fan and heater stuff.---Vernski
http://www.truckandcarshop.com/trucks60_72/t60_039.html
Vernski is offline   Reply With Quote
Old 01-13-2010, 02:07 AM   #7
NelsonMahrt
Talking Re: Updated Heater
Thanks for the site information. Now I just have to find out how this thing (resistor) is wired or where I need to run wires to/from. LoL
Old 01-13-2010, 12:45 PM   #8
62gmc910
62gmc910's Avatar
Re: Updated Heater
http://67-72chevytrucks.com/vboard/s...d.php?t=373698 does this help
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-14-2010, 04:30 AM   #9
NelsonMahrt
Re: Updated Heater
It helps, that I now know what the plug looks like, but I need to know where the other end of the 4 wires go to. The truck had the delux heater and factory air, all thats there now is the inside/outside heater box (Inside has melted a bit, but is usable for now), a universal 2 speed heater dial (conected to the heater motor) and 3 switches/resistors with no wires connected. The fuse box is some after market POS, but the dash works, wiper motor works when it wants to (will check it after getting the heater up to speed.
Thanks to everyone helping on this! I can wire the engine, lights ect, but never did anything to a heater or air.
Old 01-14-2010, 06:06 AM   #10
816allen
816allen's Avatar
Re: Updated Heater
My stock one works great i just flushed out the heater core replaced the fan on the motor because it was making niose replaced the hoses inside the cab made sure the vent inside was cleaned out and man my heater works great!!!!
Blows real hard too!
96 Burban Sold
99 Z71 Sold
65 C10 Sold
72 C10 Sold
87 Short Bed Lowered Daily Driver
http://s623.photobucket.com/albums/tt314/sswagon/
http://www.chevygmcofkc.org/forums/forum.php
816allen is offline   Reply With Quote
Old 01-14-2010, 12:53 PM   #11
62gmc910
62gmc910's Avatar
Re: Updated Heater
are you just looking for heater fan or are you trying to fix the AC now too
Old 01-14-2010, 01:03 PM   #12
62gmc910
62gmc910's Avatar
Re: Updated Heater
better still post pics of what you have and maybe we can figure this out
also look at the wiring thread
http://67-72chevytrucks.com/vboard/s...d.php?t=375602
