L.E.D light bulbs?
anyone know where i can get L.E.D. bulbs for my taillights? i m in the process of molding them in, i dont want to go with a L.E.D. conversion kit like lmc has, cause i will never b able to change it, but i can change the bulb, thanx in advanced!
also, does anyone know where to find a MOLD in strip about the length of the side marker? i am also going to flush mount this but cant find a strip small enough, thanx again! ![]()
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
Re: L.E.D light bulbs?
Still plays with trucks
Do a search for 1157 LED for the brake lights and 1156 LED for the reverse lights.
![]() ![]() I have used the direct replacement bulbs on other vehicles and they worked better than the stock bulbs. Look for the ones with LED's on the sides of the assembly as well as the front. The more LED's the brighter it will be typically. I was told to use the same color LED as the lens you are putting it behind for the best light so that is what I did.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
In the Forgotten far North.
![]() Join Date: Jul 2007
Check out www.v-leds.com as well. I've been getting all my lights from them since I discovered them. I especially like the strip lights they have, variety of colors, lengths and brightness.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#5 | |||
![]() Quote:
3/4 Ton Rodder
I just replaced mine about an hour ago. I think it is a great improvement.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
well im definately going to get some ordered! will be a while before i need them now anyways, but its better than stock! and the l.e.d. conversion has to burnout SOMETIME, and i will never be able to get to it,
3/4 Ton Rodder
You can get the LED replacement 1157's at AutoZone for $20 including tax.
#9 | |
haha, ford guys...
