01-09-2010, 11:55 AM | #1 |
Another Cab swap ?????
I have a 67 swb with typical jersey rot through the floors, rockers, cab corners and mounts, windshield area...EVERYWHERE! I found on CL a guy selling a 69 cab from a c-50 or c-60 with almost no rust. I checked it out and it is legit, only to quarter size rust spots on top of the rockers. My question is although this cab looks the same as mine (even has the small back window)...will it work? The corner of the doors look like they were cut to clera the fenders and the rockers look like they were shorter maybe. I found another post on here that said...
"the cab will interchange,but the transmission hump is smaller almost flat in the c60,you would think it would be taller than the c10,but it isn't.the doors are the same,windshield wiper panel,cowl panels,and hood will work.grille will work but you have to use your old grille mounts out of the c10.if you find a c60 lcf(low cab foward)nothing will work.the lcf is the one with the short hood,front corners of doors are cutout for fenderwells." That is what this cab is off of a "low cab forward" truck, I'm just seeing if that post is correct or if I can buy this cab and save myself a ton of sheetmetal work. Thanks for any help |
01-09-2010, 12:01 PM | #2 |
SWB 4x4 Collector
Re: Another Cab swap ?????
No, the cab will not work. The fenders are different to how they bolt up, the firewall is a big difference, and the floor is different. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
