Old 01-09-2010, 12:08 PM   #1
smackmatic
smackmatic's Avatar
What would happen if.......
What would happen if I put a set of shocks designed for a 3" drop spring, on my front suspension even though I was running a 2" drop spring?
smackmatic is offline   Reply With Quote
Old 01-09-2010, 12:44 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: What would happen if.......
It could bottom out. If this happens to often, it will destroy the seals in the shock, and could rip the shock loose.
That's worse case scenario. Did you check the part number? It's possible the same shock is called for in either applcation.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-12-2010, 07:57 PM   #3
smackmatic
smackmatic's Avatar
I actually had 3 in drop springs with matching shocks from cpp. I ran this setup with 2 1/2 in drop spindles, and found that I needed to raise the truck up a bit. I installed the 2 in springs with the shorter shocks. I get alot of bump steer, but I cant see how the shocks could cause that.
I guess I could put the 3in springs back on...
Old 01-12-2010, 08:58 PM   #4
Wild83C10
Wild83C10's Avatar
It's possible you could reach the maximum extension on the shock. However before you change back to your 3" springs you can check your suspension travel limits. If the bump stops/limiters limit the suspesion before the shock over extends or fully compress then you should be ok. Just remember the bump stops may deflect a bit more under driving conditions then when in your garage on a jack.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-13-2010, 01:01 AM   #5
CPPJEFF
A 2 inch drop spring runs ALOT shorter shock (part# 1200gll) the 2" drop runs a (part#4809) and i am at home and not at work so i dont have my chart but the collapsed and extended measurements are quite a bit different, i dont suggest it. Fell free to call me at the shop during buisness hours for exact specs.
CPPJEFF is offline   Reply With Quote
Old 01-13-2010, 05:07 PM   #6
smackmatic
smackmatic's Avatar
I have run this setup for a while now, and the ride is not as smooth as it used to be.
When I had the 3in springs installed the tires would rub the inner fender wells. I wonder if the new cpp spindles would help? I have aset of Mcgaughys spindles now.
Old 01-13-2010, 05:23 PM   #7
CPPJEFF
Yes the new spindle we made is for exact issues like the one you have. This will cure your issue for sure.
Old 01-13-2010, 05:42 PM   #8
smackmatic
smackmatic's Avatar
Can I still use six lug rotors with them?
Old 02-21-2010, 07:31 PM   #9
smackmatic
smackmatic's Avatar
I installed a set of correct length KYB shocks today. Got rid of the bump steer and rides great! Smoothest riding vehicle in my fleet now!
Old 02-22-2010, 09:14 PM   #10
DKN
Active Member
Yes you can. The new spindles will run the 5 and 6 lug factory rotors, and CPP 13" rotors in any bolt pattern.
Danny Nix
CPP
DKN is offline   Reply With Quote
