opinon on these wheels
I found these wheels for sell they are 8 lug 17"x8" Dodge 2500 takeoffs.
Any thoughts on how they would look on a square body? It is hard to find a decent 8 lug wheel and I can get these for a decent price. ![]() This is the truck....It will be lowered and have a short bed conversion done sometime in the future. ![]() Last edited by kelgar50; 01-09-2010 at 01:52 PM. |
It followed me home?
Re: opinon on these wheels
I think they would look good as long as you could do something about center caps?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I was wondering if the chevy cap might fit, the guy was only asking $200 for all four wheels.But I just called they sold the first day.
I guess I will keep looking Last edited by kelgar50; 01-09-2010 at 02:13 PM. |
did chevy ever make an 8lug 3/4t short bed?
yeller
The backspacing would be all wrong for those...they would likely sit in too far, not to mention there is virtually no dish on the outside...something that makes newer rims look crummy on older vehicles IMO.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Anytime an older truck like ours has a newer wheel, the offset is wrong so the wheels are tucked way in under the wheel wells. In contrast, put your wheels on a late model, and they stick way out. Look around for an old truck with new wheels and see if you like the way it looks.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Truck Nut
![]() Join Date: Jun 2007
The H2 wheels look good.
Tony Kee Texas Square Bodies |
Sure do. See them for sale from time to time.
![]() ![]() Last edited by joe231; 01-10-2010 at 01:06 AM. |
BAD BOW-Silverado XST
As far as I know, all three truck makers have interchangable wheels. The problem is center caps.
#13 |
Ford changed to a metric pattern of 8 by 170mm in late '97, I believe.
But as far as I know dodge and chevy are still 8 on 6.5 bolt circle (which is 8 by 165.1mm)
#14 |
Like others said you don't want those wheels as they would stick in way to far, might even rub drivetrain parts! They would also stick in 2-3in. and look bad.
Are those 2010 Dodge 2500 wheels? Those trucks have only been out like one month. |
#15 |
Yes they are, I think I will just get some HD2500 take offs for now.I have seen those on these trucks and they still look good.
#16 |
Ford and Dodge wheels will fit on a GM, but not the other way around. GM uses a smaller hub hole than the others. Aftermarket is fine, had 8 lug wheels on all three and fit no problem.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
