Old 01-26-2003, 07:09 PM   #1
Dropt72Shortbed
Dropt72Shortbed's Avatar
removing steering column and other parts... need help
this is my first time doing this, im swapping cabs so i need help on removing my steering column, all the pedals and other underdash stuff. any tips or steps on how to remove these things would be much appreciated, especially on the column, im not sure what the easiest way is...
its an automatic tilt column if it makes any difference.
Dropt72Shortbed is offline   Reply With Quote
Old 01-26-2003, 07:54 PM   #2
JimKshortstep4x4
Talking
Steering column removal.
Remove steering wheel, if your seat is out, you can leave the steering wheel on.
Separate column at first joint, (leave extension and rag joint on box for now)
Remove shift linkage from outside lever
Remove clamp on column at outside fire wall
Remove inner retainer at base of steering and pull
rubber seal free of fire wall
Remove upper trim
Remove cover plate
Disconnect wires
Remove upper clamp and lower steering column
and rotate column so that shift arm will clear hole in firewall.
(It helps to have someone help you guide it through)
I don't think that I forgot any steps.
To get the clutch and break pedal assembly out, remove dash
master cylinder/booster and proceed from there to remove clutch linkage and mounting bolt.
Good luck!
Jim
Old 01-26-2003, 08:18 PM   #3
Dropt72Shortbed
thanks jim, i decided i didnt feel like waiting so i just jumped right in, only took me 20 min to do. now im tackling the wiring, next is gas tank, brake, parking, gas pedals then im good to take the cab off.
anyways time to watch the superbowl, ive already missed the beginning
